Cars & Trucks Logo
P
PEGGY MCDONALD Posted on Feb 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Front end shakes at 50mph but stops at55mph why
Sean Piquet
Level 3:
  • Cars & Trucks Master 1,867 Answers
  • Posted on Feb 26, 2015
Sean  Piquet
Level 3:
Answers
1867
Questions
Helped
610882
Points
7259
Because one or both of the front wheels are out of balance.
1. You need to have the front wheel/tire package rebalanced by a competent balancer. Go to a good tire retailer. They have the equipment to do the re-balancing for you. Don't go to the cheapest shop you can find and hope they will do a great balance job for you.
2. If you still have the vibration after re-balancing (assuming it is done well) you will either have a faulty tire or tires (out of round or a heavy spot in the tire) or there is a problem with one or both of the wheels. If either of the front wheels have been slightly bent out of shape from abuse you will get a vibration in the front end of the car and in that event the wheel needs to be replaced. If you have a cheap brand of tires fitted to the car and the re-balancing does not solve the vibration problem I would suspect the tires first. Cheap tires will typically give you problems like this if you buy them but better brands can have tire faults also.
3. Do not let someone tell you that a front wheel alignment will solve a balance problem with the wheels/tires. It will not because the vibration is caused by the rotating wheel and tire. By all means have a wheel alignment done again - because you need to do this on the car about every 10-12000 miles in any event - but doing this will not solve a balance issue.
4. If you want to run a test before doing any work have the rear wheels on both sides moved to the front of the car and the fronts to the rear. Then check if you still have exactly the same vibration. If not then you know where the problem is. If you still get exactly the same vibration or a similar front vibration with the rear wheels fitted on the front, then the balance on the rear wheels/tires will need to be checked and re-done as well.
2answers
I have a shake in the front end when traveling 40-50mph
have an inspection done on the front end to determine for worn failing parts in the suspension and steering. Then have a wheel alignment done as what you have is a castor wobble and it is serious .
When speeds of 50mph or more reached,it shakes an shimmys terrible
That sounds like a serious problem as in it should not be driven! It's hard without more information but it should be taken in and put on a hoist so all the front-end components can be checked. I've seen cars where one tire that was very low on air would cause that. But, I've also seen vehicles with broken frames, or components that were so worn out they they actually fell off going across a parking lot. Sorry, but I can't be more specific.
Ed
1helpful
2001 Buick park avenue shakes going down the
Have the alignment checked on the front end.
6helpful
3answers
Front end shakes at 50mph, possible stabalizer bar,
Do a replacement. There is no way to adjust the bar.
2answers
My 1993 pontiac bonneville's front end shakes when i accelerate to 45-50mph, could this be becuse of a bad ignition coil? or something else?
Generally a front end shakes at that mileage is do to tires needing balanced especially if it stops when you go over 50 or more
Front end vibration
Sounds like a separated tire, alignment will NEVER cause a shake. Or you have a very loose front end part or both.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
