Cameras Logo
A
Anonymous Posted on Feb 26, 2015
My hbc161e wont power up when the battery cover is fully closed
Works when cover is partly open
Harrie
Level 3:
Top Expert:
  • Cameras Master 6,746 Answers
  • Posted on Feb 26, 2015
 Harrie
Cameras Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1285862
Points
83153
Connected to the battery cover is a switch, stopping all activity, and switching off the camera, when the door is opened. At least that is how it should function.
This is to avoid the camera accessing the memory, while the battery is pulled out. This could damage all pictures already on the memory card.
So when the door is closed and the camera is not starting, it could imply something is pressing to hard on the "safety" switch.
Try to find out what changed in or around the battery door. Try to find out where the switch is and why it is acting strange.
Like some debris where it should not be at something came lose.
Power wont turn on
If the camera will not power up then please check the following:
1. That the batteries are inserted correctly. Two should be facing upwards and two downwards. With the camera facing you (upside down) then the first battery on the left should have the positive terminal up, the second down, third up and last one down. If this does not work then ensure the slider switch to close the battery cover is fully closed - sometimes this sticks - as this closes a microswitch. If the camera still does not work then a fuse will have blown in the camera. This would be a very expensive repair. Hope this helps
Lens Cover not fully open
It sounds like a problem with the firmware in the camcorder itself. As an authorized Sony repair person, I have gotten no technical bulletin on this model. The firmware is preloaded into the microprocessor IC. You will need to have this unit looked at by an authorized Sony repair center who specializes in camcorder repairs or send the unit to a Sony factory service center. good Luck
I typed this in before this screen came up asking for it again but I will type it in again. I was retracting the top from the closed position and it starated to open until it reache about the 1/2 way point...
No unfortunately you will need to look at replacement of the wind motor years ago manual winders were installed but no power option was available best solution replace your winder motor and resolve you issue.
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
5helpful
2answers
Turn the power off and on again
1helpful
Lens keep extended in an out
3helpful
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
1helpful
3answers
VPC-T700 Wont Turn on
hiak, I had the same problem with my camera. Try opening the battery cover and pressing down onthe battery while turning on the camera. If the camera turns on you have a poor conection between the battery and the camera.I folded a small piece of paper and put on top of the battery then closed the cover.Its worked like new since.
2helpful
Workabout pro wont turn on even with full charge
Make sure that the battery cover screws are in closed position. There is sensor that cuts power to device if battery latches are not completely closed.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
