Question about JVC AV-27230 27" TV
JVC TV You can hear the sound on my TV and it still changes channels and volume but has no picture. There is only a black screen. Any ideas?
  • Anonymous Nov 18, 2007
    I have no picture when I turn on the TV
  • cooks4100 Dec 16, 2007
    I turned on my TV this morning and no picture. The channels change and there is volume but the screen is blank? Did the tube blow out? The TV is only 6 years old. Help.
    Problem Solver:
  • 13 Answers
Call the service. There is nothing for you to do inside the TV!!!!!!!!!
Posted on Nov 20, 2007
Sound ok but no picture
see the b. diagram and test the power supply ;transistor, fuse, filter, switch, c.breaker rectifier,IC regulator voltage.
measure the horizontal output =125vdc
all other circuit:12vdc
Oct 17, 2012 | JVC Televison & Video
We have a large screen TV and it displays a solid
your closed caption system is turned onn to its TEXT FUNCTION use your remote to find the CC or closed caption option and turn it off and the block will go away . good luck
Oct 26, 2009 | JVC Televison & Video
No data is sent to the screen
When the screen goes completely black, shine a very bright flashlight closely at the screen. If you can see the image, then the most likely problem is that the backlight inverter has failed.
The inverter is a circuit board that works like a flourescent light ballast. If the inverter fails, there is no backlight, and the screen is black.
Since the invertor is a high-voltage component, I would also listen for any unusual sounds associated with the failure: e.g. buzzing, whistling, popping.
To rule out some sort of connection failure, see if you can recreate the failure mode when using the TVs internal setup menu. The setup menu does not rely on any external inputs....of course neither does the volume control or channel indicator on the screen.
Oct 07, 2009 | Philips 32PF7320A 32 in. LCD Television
Vizio GV47L screen went black and is now unresponsive
Could be the power supply gone bad.
No easy solution I'm afraid.
May 20, 2009 | LG 47LC7DF 47 in. LCD HDTV
I get sound but no picture on my apex at2402.
if there's a channel and volume display but no picture,the problem of your tv is is a resistor value from 10K ohms up
Oct 10, 2008 | Apex Digital AT2402 24" TV
civilman, the first set has either no high voltage or is collapsed vertically, until someone checks for high voltage there is no concrete answer, the AV27730 is vertical collapse from your description, either the voltage to the vertical IC is missing or the vertical IC has failed, not a big deal cost-wise, hope this answers your questions, if not e-mail me back, good luck, BMW Rider
Dec 20, 2007 | JVC AV-27730 27" TV
Sound with no picture
the problem is in the backlight try to measure the supply.and replace the inverter.
Dec 05, 2007 | Toshiba LCDTV/DVD Player 19HLV87
Black menu screen pops and hides half the tv.
that is close caption, get your remote control and press the close caption button.that's it
Oct 31, 2007 | JVC AV-27020 TV
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
How to get rid of a black screen on my tv. sound is ok
If you mean that you get a black box, with a little of the picture visible around the edges, then your closed captions are on and set to TEXT. This puts a black box on the screen about 10 seconds after changing the channel. Go into the menu and turn off the closed captions and the picture will be back to normal.
Jul 07, 2007 | JVC AV-27530 27" TV
JVC AV-27230 27" TV Logo
65 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
