Question about Acer AL1912 19" LCD Monitor
Monitor keeps saying self test everything working check plugs
I have checked everything. Monitor keeps saying it is self testing and it is working fine so check monitor plugs and computer power supply. I did this. It all powers up but nothing comes on the monitor besides this message repeatedly. It is a n e-machines...2yrs old
    Genius:
  • 1,554 Answers
The self test thinks nothing is connected to it
it might be the cable or the input circuit.
not an easy issue to verify if you only have one input.
most often its is the internal board with a failed input circuit.
you can only open the unit and test the vga cable continuity.
as most have a 1 year warranty you might want to check on yours.
Posted on Apr 17, 2008
  • Karl Whisenand
    Karl Whisenand Apr 17, 2008
    oh and you have verified the vga is putting out a signal.
    if not take computer or monitor to friends and plug in.
Power comes on fan runs hard drive spins but monitor says : monitor self test.. your monitor is working correctly... check computer power and monitor cable... it was working fine the night before ...
try and boot in safe mode and check the frequency, it should be 60 htz if nothing it's possible your video card has gone out, do you have a second monitor to test?
Jul 10, 2012 | HP Pavilion 514n PC Desktop
Tip
Monitor self test
to make sure that the monitor is working fine, just unplug it from the computer. make sure that monitor is plugged in a known good wall outlet and turned on. there should be self test feature check on it that scolls around the monitor screen. for no dell branded monitor there should be a message like No signal.
on Mar 03, 2010 | Computers & Internet
Plugged in the monitor and it keeps saying self test feature check. how can i get this to stop?
Can you see your desktop while this is happening? Make sure that in your Display Settings under the Advanced Settings or Properties that you have the correct refresh rate for your monitor selected.
Mar 02, 2011 | Dell Computers & Internet
My monitor is blank it just keeps saying self check its a dell flat screen
If it shows "Self test feature check" the cable (VGA / DVi ) is unlplugged on the computer/ tower. Check the cables it may be loose. If not, try replacing the VGA/DVi cables. The LCD is good since it was able to display the self test feature check.
Hope this helps.
Mar 24, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Dell e137fp monitor flashing green...
Below you will find my recommendations for troubleshooting this issue:
1. Reseat the power cord and verify a good power source.
To reseat the power cord, follow the steps below:
1.1 Power down the system.
1.2 Unplug the power cord.
1.3 Wait approximately one minute.
1.4 Reseat the power cord.
1.5 Verify that the power cord is plugged directly into a known good power outlet.
2. Verify that the monitor is receiving power from a known good outlet and bypass any power strips.
To test the power outlet, perform the following steps:
2.1 Unplug the monitor power cable from the power outlet.
2.2 Plug in a different device, and verify that the device is operational.
2.3 If there is no power try another outlet. Remove any power strips and try plugging directly into the main power outlet.
3. Verify the monitor is powered on and the power button is engaged.
Ensure that the monitor is powered on and that the power button is fully engaged. To do so, check the power LED on the front of the monitor; it should be lit.
NOTE: There are two types of power switches:
A mechanical switch characterized by a long travel. You have to push it further and you will hear an audible click.
An electrical switch that has a short travel and almost no click.
A lit monitor LED can be any of the following:
* Green
* Blinking green
* Yellow
* Blinking yellow
* A combination, such as alternating green and yellow
Any of these states indicate the monitor is receiving power and that you should proceed.
4. Swap power cables.
To try a known good power cable on the monitor, follow the instructions below:
4.1 Turn off a working monitor.
4.2 Unplug the cable from the back of the working monitor, and unplug the cable from the wall.
4.3 Unplug the cable from the monitor in question.
4.4 Plug in the cable that came from the working monitor.
5. Run the monitor self test.
To run the monitor self test, perform the following steps:
5.1 Power off both the computer and the monitor.
5.2 Unplug the video cable from the computer or video card.
5.3 Reseat the power cord to the monitor, ensuring it is plugged into a known-good outlet.
5.4 Power on the monitor.
NOTE: The monitor self test will move around on some monitor models. If the monitor self test moves, allow it to move to the affected areas of the monitor to check for the problem described.
If the Self test failed, it's possible that the monitor is faulty. Contact dell to check if it's still under warranty so they can replace it.
Jun 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
My samsung lcd monitor is very dark and can't be adjusted
Hi strat1971,
So the monitor buttons don't work also right? Yeah, normally you should try to adjust the brightness control first on the monitor. If that doesn't work next step would be ofcourse to check the cabling of the monitor to the computer. Try reseating the video cable from the back of the computer. If no go, then the next step is running the monitor self-test. You can do this by just disconnecting the video cable from the back of the computer, and leaving the monitor plugged into the power outlet.
All monitors has a form of self-test that it does to check the functionality, usually a picture or a color bar display on the screen or even a message that the monitor is on self-test. If it's still dim on that screen, then sadly you already have a hardware problem that may require to you buy a new monitor.
Hope this helps!
Peace! :)
Oct 22, 2008 | Computers & Internet
Monitor not working
These messages appear during if the video cable becomes disconnected or
damaged.(most likely you will need to replace it)
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
Nov 14, 2007 | NEC MultiSync LCD1830 18.1" LCD Monitor
Acer AL1912 19" LCD Monitor Logo
123 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
