A flag pole is at the top of a building. 250 ft from the base of the building, the angle of elevation of the top of the pole is 50 degrees and the angle of elevation of the bottom of the pole is 48 degrees. Determine the length of the flagpole (to the nearest foot).
New cylinder head bolts coated with a sealant (such as GM 1052080).
Torque the bolts in the proper sequence (1-8) to 37 ft. lbs. (50 Nm).
Using a torque angle meter turn the bolts 90 degrees in the proper
sequence.
Left side exhaust manifold. Torque the bolts to 12 ft. lbs. (16 Nm).
Spark plugs. Torque the plugs 11 ft. lbs. (15 Nm).
Right side rear cylinder head:
Cylinder head bolt torque sequence-3.4L engine
New cylinder head gasket
Cylinder head on top of the gasket and make certain it is lined up properly with the dowel pins
sequence.
Right side exhaust manifold. Torque the bolts to 12 ft. lbs. (16 Nm).
Spark plug wires
Exhaust crossover pipe. Torque the fastener to 18 ft. lbs. (25 Nm).
Valve rocker arms and pushrods. Torque the fastener to 89 inch lbs. (10
Nm). Using a torque angle meter torque the fastener an additional 30
degrees.
Lower intake manifold. Torque the bolts to 115 inch lbs. (13 Nm).
Upper intake manifold. Torque the bolts to 18 ft. lbs. (25 Nm).
New cylinder head bolts coated with a sealant (such as GM 1052080). Torque the bolts in the proper sequence (1-8) to 37 ft. lbs. (50 Nm). Using a torque angle meter turn the bolts 90 degrees in the proper sequence.
Cylinder head bolt torque sequence—3.4L engine
Spark plug wires
Valve rocker arms and pushrods. Torque the fastener to 89 inch lbs. (10 Nm). Using a torque angle meter torque the fastener an additional 30 degrees.
Ok these are tricky, so what you need to do is check your poles and connectors. You should have long poles and assorted connectors.
A bit of mathematics and you'll have it done in no time.
Ok lay out the poles and sort into longs and shorts.
Sort the connectors into 2 pole connectors (straights) and 3 pole connectors (three way)
Now check the angles on the three way connectors, sort them into groups. some should be slightly angled, these are the roof connectors and the others ones are 90 degrees and or more squarish these are the floor corner connectors. There should be 4 floor corner connectors and There will be two connectors that fit onto the end of roof front and back of the tent.
Sort out your poles and work out how many you need for each dimention. Basically your tent is a cube with a triangular prism on the top so you will need enough poles of even length to make the base and top bit of the cube and then even lengths of poles to make the upright sides of your cube. There should also be 4 four way connectors for attaching the roof. the top of you cube is the base of the triangluar prism.
Hope this helps. TIP once you get this together, MARK the conections with NUMBERS EG: 2 / 2 / 2 one number on each bit (the connector and each pole that is attached to it), this way when you pull it apart you can reconnect it much easier later on.
