To replace the quick release blade holder on a Ryobi jigsaw, you will need to follow these steps:
Unplug the jigsaw and remove the blade.
Turn the jigsaw over and locate the blade holder.
Use a Phillips head screwdriver to loosen the screws that hold the blade holder in place.
Once the screws are removed, you should be able to lift the blade holder out of the jigsaw.
Insert the new blade holder into the jigsaw, making sure that it is properly aligned with the blade clamp.
Secure the blade holder in place using the screws that you removed earlier.
Reinsert the blade into the blade holder and make sure that it is properly secured.
Test the jigsaw to make sure that the blade holder is properly installed and functioning as intended.
It's important to be careful when replacing the blade holder on a jigsaw, as the blade is sharp and can cause injuries if handled improperly. Make sure to use caution and follow the steps carefully to avoid accidents.
With your new blade locked into its slot, you can now loosen the sawblade screw by turning it counterclockwise until all pressure has been released and then put back on the small-cap over the top of the jigsaw before turning clockwise again with your hex wrench. https://sawedworld.com/how-to-put-a-blade-in-a-ryobi-jigsaw/
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
There is a blade release that you have to push up while inserting blade. If this isn't the problem, there are many types of blades for different jigsaws. You need the one for your brand. Take an old blade with you when you purchase. Good luck
There is a black plastic switch where the blade is slid into the jigsaw. The black plastic switch can be seen and accessed from the front of the jigsaw through the clear plastic sight guide...You pull the black switch toward the bottom of the jigsaw and it opens the space for the blade to slide into, when you release the switch it will close the space and lock the blade into place.
