Question about Epson Stylus Color 740i InkJet Printer
Is there a fix to bypass the fault?
Over a period of time and use the printer faults out. All 3 lights are on solid. (Paper, black ink, and color ink). Can't print in that state.
I have a number of these printers in my employ, and am tired of replacing them. Can this problem be bypassed? There must be a way. Assumption here is that maybe an e-prom has timed out?
    Brigadier General:
  • 6,966 Answers
You may want to try resetting the Epson printer(s). There is a 3rd party utility/software specifically for that purpose. It may be downloaded from here.
Hope this be of use/help to you. Pls post again how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 13, 2007
Just installed a 1200 all in one HP printer and it goes through the motions of printing but nothing is on the paper, i have deleted, reinstalled, check every setting possible, done everything that the...
Many a times the cartridges get empty.There is ink in the cartridges,this ink gets over or many a times dried up.Remove the cartridges and see.There will be a steel color nozzle at the base of cartridge,from where the ink comes out.Touch the tissue paper to that base and see,if there is ink coming out.Actually the ink should come out.There will be two cartridges in the printer.One black and one tri-color.On black cartridge when you touch the tissue paper you will get black ink on tissue.On tri-color cartridge when you touch tissue on its base you will get three colors,that are yellow--- blue and pink.( In printer language its called cyan--- yellow---magenta color).If there is ink in the cartridge then it should print,If you have replace the cartridge,then on its base there is a blue color tape.That tape has to be removed from its base.If the tape is not removed the cartridge will not print.-------- One more thing.Before doing any thing.Just do a self test and see if the cartridges are working. The procedure of self test is as follows:--- " 1) Turn the printer on.2) The power on green light should be steady green,not blinking green. 3) When its steady green at that time.Press the cancel and color button both together. 4) By doing this the green light will flash,and printer will take the paper. 5) On that paper the self test will get printed.But if the printer takes the paper and it comes out empty /blank then its cartridge fault.But if the self test is getting printed,then yes its confirmed that there is communication fault between printer and computer.In this case,replace the usb wire.Try new brand usb wire and see if that is helping.One more thing.When you install the printer driver.At that time never keep the usb wire connected between printer and computer.Only keep one side of usb connected to computer tower.In between the installation procedure.The message will come up on your computer screen" this message reads,connect the usb wire to printer.At that time connect the usb wire".As you connect the usb wire the message will come up on your computer screen.The printer is detected.If this message comes up then only your printer will work.If this message does not comes then,there is any of the three things faulty,that is usb wire,the usb port on printer side or usb port on computer side.If usb wire is faulty you can replace this wire with new and check.Its not a costly wire.But if any of the ports are faulty,then this ports are internally soldered on the main board.This ports needs to be re-soldered.This can be done by any printer/computer repair tech.Its hardly a 10 minute job to re-solder loose usb port. ------------- Try this troubleshooting procedure.This will help. Thanks.Helpmech.
Jan 27, 2011 | HP PSC 1210v All-In-One InkJet Printer
Changing cartridge
You need to blot the bottom of the ink cartridges on a damp paper towel and look for 3 solid ink lineson the color one and a solid black from the black one. If any colors are missing, especially yellow, it won't pass alignment. Some people have been getting defective cartridges where there's no yellow. If you get good lines on the towel it should pass alignment.
Jan 29, 2010 | HP OfficeJet J4580 All-In-One Laser...
Lexmark x1270 wont print color even though the cartridge is full.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know.
Oct 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
The printer cannot read from the computer, what do I need to do tried all cables
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridges. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." Then plug the printer back in.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault. The issue may be a communication problem, or perhaps a software conflict.
Oct 18, 2009 | Lexmark X1240 All-In-One InkJet Printer
My lexmark x1290 isn't printing tho i have new ink cartridges
Oct 02, 2009 | Lexmark X1270 All-In-One InkJet Printer
My X1240 will not scan copy or print even with the computer.The only thing it will do is that the power light will come on....
Oct 02, 2009 | Lexmark X1240 All-In-One InkJet Printer
Lexmark x5495 all in one.paper does not come out when printing
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridge. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
May 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark z715. paper comes thru with no ink in it. cartridge is full and appears to be installed oorrectly..please help
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "All Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
1. Turn the power to the printer "off."
3. Press the "Power" button once while continuing to hold the "Paper Feed" button.
4. Keep holding the "Paper Feed" button until one sheet is cycled through.
5. The test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
May 05, 2009 | Lexmark Z715 InkJet Printer
Try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Oct 13, 2008 | Epson Stylus Color 1160 InkJet Printer
Lexmark x5150
Your ink cartridges have dried out. Replace the black to confirm this prognostication and, if black works, replace color also. If you are into refilling ink cartridges youself try soaking the black one in 91% rubbing alcohol in a small ziploc type bag for several days. when the alcohol becomes ink colored, remove the cartridge from the baggie, dry it with tissue paper, reinstall it in the printer and up to 3 times run a clean the nozzles page until it prints a solid black line. Repeat with the color cartridge. Good luck.
qwester1
Apr 02, 2008 | Lexmark X5150 All-In-One InkJet Printer
Epson Stylus Color 740i InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
