SOURCE: How to disassemble crank bearing on Schwinn Mesa Mountain Bike
You wil need a couple of special tools, or be fairly creative with the tools you have.
Once you have it opened up ou can determine if you need new bearings or crank axle.
to assemble, reverse above procedure, insuring bearing play is minimalized.
Hope this helps.
Ed
SOURCE: bike pedal arm keeps falling off as i pedal.
You need a new crank arm. If you ride with the nut loosened what happens is the square part of the bottom bracket shaft wears the hole out in the aluminum crank and it no longer fits snugly no matter how much you tighten it down.
SOURCE: Bad crank bearings can move crank arms small amount.
clicking can be a stiff link in your chain.
SOURCE: I have a 2008 Specialized
You probably need to completely remove the crank, grease it and reinstall it.
http://www.parktool.com/blog/repair-help
http://www.parktool.com/blog/repair-help/categories/crank-service
Find the correct BB type and follow the instructions. Of course, a crank extractor tool (which Park makes) is required, so if you don't have one you might want to take the bike to a shop and weigh the pros and cons of equipping for self-maintenance or having them do it once in awhile.
SOURCE: Raleigh Bicycle Passage 3.0 Crank arms
Yes, once you remove the crank arms and the pedals, you will need a special tool to remove the bottom bracket that contains the sealed bearings.
Here is a set of nice quick YouTube videos on how to replace a bottom bracket which shows the tools and techniques required:
http://www.youtube.com/watch?v=moIUDAyRH2I&NR=1
http://www.youtube.com/watch?v=QrkxaNgL6Y4
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will automatically open a new browser window for you and display the video.
Here is a link to the general description of your bike:
http://bicyclevillage.com/product/raleigh-womens-passage-3.0-3894.htm
And here is a link to the technical details:
http://bicyclevillage.com/product/specs/raleigh-womens-passage-3.0-3894.htm
If you want to replace the bottom bracket yourself, just bring those details into your local bike shop and ask them for the correct tool and replacement bottom bracket to purchase. If you just wanted to have them do the work, I don't think they would charge you more than $30 labour for it, plus the cost of parts of course.
Anyway, please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
