Question about Uniden Cordless Phone
LED display isn't displaying - Uniden Cordless Phone
I have a old led display, and dont know how to use it. all it says on it is micro sign, london sw.6. and cherry on back of control.
mally
Posted on May 07, 2008
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Laserjet 1312 display blu, no messages display led
This is probably because of a defect or missing RAM chip. Try replace the RAM chip on formatter board or call for service if the product is still under warranty. Check for yourself HERE.
Good luck.
Oct 24, 2013 | HP LaserJet 3600n Printer
What's your problem?
First, make sure this isn't coming from your signal source; these items are not listed in any of the functions described in the manual for your monitor.
If disconnecting, changing or turning off your signal source doesn't get rid of the control item display, try resetting the monitor (maybe the display has some extra firmware features not in the documentation):
  1. Press the Menu button on the side of the monitor.
  2. From the On-Screen Display, navigate to the Setup&Reset menu using the arrow buttons, then press the Source/Select button.
  3. Navigate to "Reset" and select it.
This should restore everything to the factory default setting and get the TV/monitor out of whatever mode it's in.
Dec 03, 2011 | Samsung 23IN Led 1920X1080 5M1 PX2370 Dvi...
I just bought a new pyle car aduio radio and the display has now gone out after three days why
Ok, for starters, Pyle is close to the bottom of the barrel when it comes to electronics. I think Dual is the only one worse. Your LED display has probably malfunctioned. I can definately understand your frustration. There is not a whole lot that can be done if that is the only problem. The old saying is, you get what you pay for. Sorry there isn't alot to be done, other than to replace the radio.
Aug 11, 2011 | Car Audio & Video
There is an EE code. The machine just beeps.
EE
Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
Hope helps.
Jun 27, 2011 | Washing Machines
I have prolem in samsung LED that no display shown when i turn on....can you please advice. thanks....Peter
send me detail on jogindersingh47@yahoo.com 1) if yours LED power on and display of window not giving then problem from cpu. a. first replace yours RAM and check display. b. then display cable and check display. c. Install new Display card and check display, if not giving display it means motherboard have a problem 2) LED not giving power on then problem from monitor a. replace monitor power cable and check display b. monitor logic card have aproblem
Mar 16, 2011 | MPC Computers AOC 7F 17" CRT Monitor
I need NOMA N1508 manual.
answer 1 Function and operation
1 - This timer has 3 working modes
a - Auto Mode(AU)
b - Auto and Temperature Control Mode (AC)
c - Manual Mode (LL)
Press "MODE" button and the LED display will cycle through these three modes.
2 - There is an output indicator light which turns Green (On all modes) and red (Off - manual mode)
3 - There is a bettery backup that can retain programs for about 1 week after power outage.
Operation
1 - On first use . Connect the unit to 125V AC power source. The LED display blinks 'C'. The unit at this moment is in initial state, where time and program need to be set.
2 - Press the "TIME" button, the LED display will now show "12.00", now the unit is entering time setting mode
a - The time interval for this product is 15 minutes
b - Press "TIME" button again. LED dislays 12:15 with each press of the time button the time increases by 15 minutes. If you press and hold the time button for 2 seconds the LED will increase rapidly.
c - After setting the time, press the enter button and the LED will display current time setting.
d - To change the clock press the "Enter" and the "TIME" buttons simultanously to enter the editing mode. Press the "TIME" button to adjust the time. Press the enter button to confirm
3 - To program press "mode" button once and the LED will display "AU" which stands for Auto Mode, press the "MODE" button once again and the LED will display "AC" which is the Auto and Temperature Control Mode. Press the "MODE" button once more and the LED will display "LL" which is Manual Mode. Press enter to confirm the selected mode. Press "MODE" button to role over these three options.
a - Auto Mode
Press "MODE" button and the unit will enter Auto Mode, LED displays "AU"
- Press "ENTER" button to confirm. LED displays "P". Press "TIME" button to set program ON time.
- After the program ON time is set press "ENTER" button to enter program ending time. LED will display "E". Press the "TIME" button to set the ending time.
- Press "ENTER" button to return to normal time display mode.
- The program indicator will be turned on after the ON time and ending time have been programmed
- Press the "TIME" button to review the program ON time setting and program ending time setting. The LED displays "P" and "E" respectively. After that the LED displays the current time.
- In case you want to modify the setting repeat step "a".
*** Note: When entering your program if no action takes place within 15 seconds it will go back to the time screen.
Press the "MODE" button and the LED will display "AU". Press the "MODE" button again and the LED will display "AC". press the "ENTER" button to confirm.
- The timer activates the load only when the folloewing two conditions are met:
1 The temperature is below -10
2 The program on time p is reached
For instructionsn on how to set the program ON time and the program ending time please refer to the Auto Mode fucntion
- The program indicator will be turned on after the ON time and the ending time have been programmed.
- When the program ending time is not yet reached, the load will be deactivated if the temperature rises above -7 and will be activated again if the temperature drops below -10. Once the prgram ending time is reached the load will be deactivated regardless of the temperature.
C - Manual Mode
Press the "MODE" button to select Manual Mode. When the LED displays "LL" press the "ENTER" to confim. The LED returns to show the current time. Press the "TIME" button to activate the timer the LEd will display ON. Press the "TIME" button again the LED will display off.
- In Manual Mode the output indicator will display red when the load is deactivated and green when activated.
- To exit manual mode press "TIME" and "MODE" buttons simultanously and the unit will return to Auto mode. The loading will be activated and deavtivated according to the previous setting.
4 Output indicator
1 - In Auto Mode ort Auto Temperature Control Mode when the loadind is deactivated the output indicator tunrs off.
2 - In Manual mode the outpur indicator turns red when loading is deactivated.
3 - In Manual Mode, Auto Mode and Auto Temperature Control Mode the output indicator turns green when the output is activated.
To reset all of your settigns including current time and programs, press and hold the "ENTER" button for 5 seconds from the "TIME" mode. answered 3 weeks, 2 days ago by Anonymous
Jan 11, 2011 | Sport & Outdoor - Others
RCA RTD315W Receiver/DVD LED display
If you are referring to the information display, it doesn't activate until you take the system out of standby (the bright blue LED at the corner is shining). When you hit the OFF button (on the system or the remote) and the blue LED shuts off, your info display comes on and says WELCOME.
Dec 27, 2008 | RCA RT2500 System
Uniden Cordless Phone Logo
204 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
