Television will not turn on consistently
We have a Toshiba TV (let me know if you need the model # - it's only about 6 yr old). Every once in a while it will not turn on unless you unplug the set, wait about 5 seconds, and then plug it back in. We've had a repairman out to look at it, but he couldn't figure out why this occurs. This has been going on now for about 3 yr. We have resorted to plugging the TV into a power strip which we turn on & off in place of unplugging the TV. Have you heard of something like this before & if so, is it fixable?
    Brigadier General:
  • 6,966 Answers
There are far better experts from this site who would know more if you can post back specific model no or preferably the Chassis no. of your Toshiba.
Just to start the ball rolling, to my knowledge, most models of CTVs since a few years back uses an internal mini computer. Like any computer it does need to be reset and in your case, unplugging (actually for a few hours) performs a hard reset . For a few minutes is a soft reset.
At times, the standby led or power led would also flash a certain sequence to indicate if there is an internal fault detected by the protection circuitry. By unplugging, you did a reset on the protection circuitry and if your problem is intermittent or develops over a period of viewing time (chances are heat related problem), then the protect will auto activate and will not allow power on the next time (if the unit is plug).
Hope that this be of some initial help/idea. Please post back and I'm sure others would be offering detailed assistance thereafter.
Good luck and kind regards.
Posted on Nov 13, 2007
I have a 6 yr old Panasonic PT 50 LC13 and I need to know how th reset the lamp. i just replaced the bulb and i cannot get the tv to turn in
To reset the lamp follow the steps below.
Press and hold "Volume down(-)" at the front panel and "TV/Video" on the remote control for more thatn 5 secs in power off condition to activate the Service mode map. You can now reset the lamp.
After that check if the symptoms still there. If yes, let me know the status of the led light(Power, Temp, Lamp) and its color to determine where the fault came from.
Sep 08, 2011 | Panasonic PT-50LC14 50" Rear Projection...
All of a sudden my 6 yr old samsung HCN653W has a
your cable box is effecting the component line in 1 or 2 in the back of the tv
Jul 12, 2010 | Samsung HCN653W 65" Rear Projection...
We just moved and noticed that our 1 yr old flat screen LCD TV has lines down the center and marks on the bottom of the screen. Is it destroyed?
There's physical damage on the address registry circuits and/or the LCD deflector its self. Tv needs a new LCD..... the cost is around $500 bucks
Nov 03, 2009 | Toshiba 42HL167 42 in. LCD Television
Infrared sensor won't work in a Toshiba TV
The remote wouldn't work on my brand new 46" Toshiba TV. Comcast person said the tv gave off an infrared signal that interferred with the Comcast remote.
Solution was to turn on cable box FIRST, then TV ( now I use All On button, which turns on cable first). If I turn on TV first, the remote wouldn't work consistently. Hope this works for you.
Aug 09, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Toshiba 43HX70 convergence problem
Yes its actually a very easy repair. You need two STK392-110 Convergence ICs and six 1.2 ohm 2watt resistors. You can get the replacement parts and instructions at the following link.
Apr 27, 2009 | Toshiba 53H71 53 in. Rear Projection...
Screen dark,wont stay on. 52hm95
Here's the online manual for your TV:
Read the section about the red/green lights in front. It sounds like the lamp went out. Mine consistently goes out once every year to year and a half. If you plan on keeping the television, purchase two bulbs, so you have one on hand in case your new one goes out.
Good luck.
Apr 19, 2009 | Toshiba 52HM95 52" HDTV Projection...
My 6 to 7 yr old television suddenly went dead
There is a board that manages the power going into your tv I would check around with local mom and pop tv reapir shops. The board is not expensive its the labor I am not sure where you live but I am sure there are local techs that work on flat panel tv's. They are pretty affordable these days. Most flat panel tv's are rated for 60,000 hrs as there life span. Hope that helps
Mar 25, 2009 | Panasonic Televison & Video
How to replace front protective screen..
in order to replace this piece, you will need to take the entire case off of the TV, undo all of the wiring inside, and behind the tube.  Once you have the old piece out, yuo need to put the new one in, be very careful, as a sligt jar could ruin it.  Also be careful to get the wiring right as a wrong cable could ruin not only the new screen you just put in but, ruin the rest of the television.
Jan 10, 2008 | Toshiba 65HX81 65" Rear Projection...
Toshiba 50h81 turn it self off then back on
Did you check the supply fuses to the convergence ICs? Did you check the output resistors
then i would start by replace the convergence ic first.
Dec 01, 2007 | Toshiba 50H81 50" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
