Question about Polaroid FDM-0700A 7 in. TV/DVD Combo
FDM-0700A Nothing works. I have replaced the power supply and it will not turn on.
  • 1 more comment
  • Maxvalocity Dec 19, 2007
    Mine will not turn on either polaroid wwants $95 for a replacment and then i have to pay to ship the old one back I told the man that that was stupid no instead of paying $200 for this unit its now going to be over $300 for it.
    The power supply wors fine it is the unit it self
  • surplustech Dec 21, 2007
    On mine the led on the power supply flashes when it is pluged in, but is on solid when unpluged. Opened the case to find a 3.6volt ni-mh battery on the main board the had exploded blowing one end completely off the board. When I unplug the power board (the one where the supply pluges in) the led stays lit, but just connect that board back to the main and it just starts flashing. Now I know chips and other devices usally don't blowup when they fail, Iam thinking some else is the cause of the problem and sent to much voltage to the battery causeing it to fail. Since I can't seem to find a service manual or a schematic on the web I'm going to had to try and trouble shoot it the old way.The time and tedious way. When I find out anything I 'll write again.
  • jricco Jan 03, 2008
    I have done research on-line and found that the black lcd screen is probably caused by the back light failing and it appears to be a very common problem. I brought my unit (which I love and can not live without) to the local electronics repair yesterday. They should have it about a week and I will send a blog once I have info on the repair. Good luck!!!
  • 3 Answers
Hi everyone, I don't know if you have solved your issues yet or not, since these posts are from a while ago, but I have had the same issue. The problem is that of the back-light inverter circuit. The original part is defective and the chip that powers the coils will continually burn out. You can pick up a cheaper replacement substitute here:
http://www.lcdparts.net/InverterDetail.aspx?InverterNumber=UI8007S-1MSS
The part can be found just behind the screen on the bottom if you take the back panel of the screen off.
Hope this helps1
Posted on Sep 29, 2008
Machine won't load disc. Keeps saying loading
Either a mechanism problem or a problem with the Optical unit inside (optical pickup) being dirty or bad.
Apr 16, 2012 | Polaroid FDM-0700A 7 in. TV/DVD Combo
How can I get a replacement remote control? Or is there a local place I can pick one up close to zip code 13901.
Hi heres one on ebay for your model
http://cgi.ebay.com/POLAROID-PORTABLE-DVD-PLAYER-REMOTE-0700-SERIES_W0QQitem
Z260547047090QQcmdZViewItemQQptZLH
_DefaultDomain_0?hash=item3ca9d06eb2
please dont forget to rate me i need a few more to get my badge thank you....
Feb 04, 2010 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Polaroid fdm-0700 with black screen display. DVD
go here and order the replacement inverter board. this will fix the backlight issue or no picture issue
http://lcdparts.net/LCDTVInverterdetail.aspx?InverterOriginal=UI8007S-1MSS
Aug 09, 2009 | Polaroid FDM-0700A 7 in. TV/DVD Combo
FDM-700A
go here and order this inverter board. this will fix the no picture or inverter backlight problem
Aug 07, 2009 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Remote does not work
try replacing the battery.
What I have done is open up the case and make sure all the water is dry. If not, use a hair dryer to dry it clean, being careful not to 'overheat' the unit in case you burn up any chips on the board.
If this does not work, replace it.
Feb 16, 2009 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Backlight doesn't work
Hey Nascar580, you can pick up an replacement substitute part from here:
The original part UI8007S-1 is defective and the IC chip that powers the coil will contually burn out. The replacement was designed due to this flaw.
Jul 07, 2008 | Polaroid FDM-0700A 7 in. TV/DVD Combo
No picture
Same problem. No picture and lost the remote. How can I fix it? Can i get the picture back by programming it hte unit itself and how?
Feb 18, 2008 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Help
Ok this is a sure fire way of getting that DVD out. Open up the unit, find the load and unload gear, rotate the gear and that should eject the carriage slide. That's it.
Sep 21, 2007 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Polaroid FDM-0700A 7 in. TV/DVD Combo Logo
240 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
