Question about Symantec Winfax Pro 10.03 (winfax10.03) for PC
"No acknowledgement received on last attempt"
This doesnt happen on all faxes, so i just want to know what exactly this means. is it a problem with the host not sending a reply back to my winfax machine in a timely manner? or is it my machine that is freaking out every once in a while? biggest thing i'd like is how to fix this.
  • 143 Answers
Usually, this error occurs after sending a page, or prior to sending all the pages of a multipage fax.
There are many reasons why this occurs, and it is not always easy to determine why.
You may want to read up on "types of modems" found in the following document
http://www.getfaxing.com/winfax/2009/06/25/first-time-guide-to-winfax-pro/
also, winfax settings could be incorrect , or you might not have the best configuration setup for your modem in WinFax.
Posted on Jul 08, 2009
SOURCE:
Cannot send faxes
check whether you have loaded the scanner software .
Sep 03, 2008 | HP Officejet 4215v All-in-One Printer
Do not know how to turn on "receive faxes". can only send faxes. How do I turn on receive faxes?
if you are able to send faxes it means you are set up correctly, meaning that you have connected your printer/fax machine up correctly to the phone lines. all you need to do is make sure the printer/fax is on while you are receiving the fax, there is no "fax receive mode" however, you need to know that if you use the same line for your phone and for your fax that your phone will ring when receiving a fax, if you answer it will ruin the fax, there is a special configuration you can access which will let your printer work more effectively, such as to intercept faxes and immediately process them before letting your phone ring, or waiting a certain amount of time or such. you can consult the specifications of your device to know the exact settings you have available.
Apr 15, 2011 | Canon PIXMA MX870 Wireless Office...
Keep receiving duplicate faxes
Some Brother fax machines are programmed incorrectly so they do not acknowledge receiving the last page of a document. The sender doesn't know you got it, and will resend.
It's harsh advice, but the only solution is to buy a different brand.
May 07, 2010 | Brother IntelliFAX 4100 Laser Fax
We are getting a Comms Error 0030 every time a fax is incoming. What does this mean and how can we stop it?
Are you receiving faxes only from one place? This error indicates that your machine is not receiving the "handshake" from the other machine. It knows a call came in and sent a request to the other machine for parameters, but did not receive a response.
If this happens with all incoming faxes, your machine may need to be serviced.
Mar 10, 2010 | Canon FAX L-120 Plain Paper Laser
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Problem receiving fax from outside source . phone rings acknowledges receive on screen but no fax comes through. other source sends faxes to other sources no problem & i receive faxes from other...
In the last statement you said you RX faxes from other sources? which means you can't RX from one or a certain source??
1- could be area code
2-could be your memory is almost full and their faxes are too long
Jul 31, 2008 | Samsung Office Equipment & Supplies
Internet Problems
Please let me know what exactly happens when you try to access internet?
Are you receiving any error message?
Jun 18, 2008 | HP Pavilion dv9205us Notebook
FAX BROTHER mfc 885cw
This is obviously a phone company issue or a defect in GE fax machine keypad or circuitry. Last but not least turn off your machine at night. Turn it back on when you wake up.
Jun 15, 2008 | Brother Office Equipment & Supplies
Symantec Winfax Pro 10.03 (winfax10.03) for PC Logo
248 people viewed this question
Top Symantec Computers & Internet Experts
Peter Dragonetti
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
