Fan belt/power steering belt
SOURCE: i replaced the drive belt on my Dodge ram 1500 its loose
Here is the schematic for the drive belt.
For further assistance contact me at FixYa!
SOURCE: i dont have the diagram
normally the diagram for the fuse box is just inside the lid and my suggestion to you is to stop by a dodge dealer and the parts department would print you off a diagram
SOURCE: Need diagram/schematic for serpentine belt replacement
Should be a tag on the core support somewhere that shows a diagram how to install your belt,usually its right on top where the radiator bolts to core support,open hood look down on top of support or its on the inside of hood open hood and look up see if theres a tag with a diagram of belt installation
SOURCE: replacing serpentine belt 2002 dodge stratus
Did this on my 2002 Stratus 2.4L. I agree with other poster, you do have to remove the passenger tire and wheel wall to do it, but the tensioner travels clockwise.
Note: I offer this solely as a description of how I accomplished the task on my vehicle. It should not be taken as me advising anyone else in any way on how or whether they manage to repair their own vehicles.
1) Engaged parking brake, loosened lugs on passenger front tire.
2) Jacked-up and placed jack-stand.
3) Removed piece of black under-carriage which surrounds the oil filter and attaches to front bumper. There are at least 10 plastic push-pins to remove and I managed to destroy half of them in the process.
4) Positoned belt over lower pulleys and tensioner (as best as possible) then used a bungee to hold the top end of belt up while I worked under the car.
5) Used a 3/8 ratchet and inserted into square hole attached to the tensioner, disengaged the tensioner (moves clockwise) then used a brace to keep the ratchet handle in that position.
6) From top, removed bungee and finished placing belt over alternator, checked the position of entire belt, reengaged the tensioner, and replaced wall and wheel.
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I have only been a free contributor to this site for the past 4-months.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
http://www.2carpros.com/car_repair_information/year/1998/make/dodge/model/ram_van/1998_dodge_ram_van_drive_belt_routing_diagram.htm
