Dell inspiron b130
Will not power up when plugged in, how do i check ac adapter?
  • Anonymous Apr 29, 2008
  • 85 Answers
Does it have a green light on it? If not.. When you plug it in the outlet source does it spark a little?
Posted on Nov 13, 2007
My dell b130 will not turn on
At first check with another working adapter of same volt and ampere. Don't use higher or lower powered adapter, that may damage the motherboard. second power jack and third is motherboard problem.
Dec 01, 2012 | Dell Inspiron B130 Notebook
My Dell Inspiron B130 will not turn on
The battery is critically low, indicating that it is not getting a charge from the AC adapter. If the system will not power on from the AC adapter, then the motherboard power connection is suspect.
Motherboards are about $100 on EBay
Feb 01, 2010 | Dell Inspiron B130 Notebook
Has power but wont boot up at all inspiron b130 notebook, was working fine 4 days ago ,
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 15, 2009 | Dell Inspiron B130 Notebook
Inspiron B130 shuts down after about 5 seconds
Sounds like a bad AC adapter not charging the system. If a known good adapter has the same issue (Or this adapter works on another system) then it is a motherboard replacement
Sep 14, 2009 | Dell Inspiron B130 Notebook
My Inspiron B130 will not charge,even with a new battery. I plug in the power cord, will not charge still. No power light, nothing
just had the same problem- the socket where you plug in the adapter had shorted out-needed to be resodered-no big~100$
BUT my ac adapter was bad as well- may have caused the short (they are cheap on ebay)
May 08, 2009 | Dell Inspiron B130 Notebook
My plug for the AC adaptor only works when I press it in. I am pretty sure it is the power jack on the PC. I don't know how to take it apart to that level to see if it can just be re soldered or not. I really would like to fix this myself so if anyone has any links to fixing the power jack on a Dell Inspiron B130 let me know.
Dec 26, 2007 | Dell Inspiron B130 Notebook
Dell B130 won't charge
From my experience with 3 DELL laptops, the problem was resolved by replacing the system board. Apparently the port the AC adaptor plugs into becomes damaged (provided you have determined it is not a battery needing replacemnet or a defective AC adaptor) and that cannot be fixed without replacing the whole system board.
Dec 20, 2007 | Dell Inspiron B130 Notebook
Dell inspiron b130
check if the ac adapter or charger has a green light on it. if not, replace the charger. for dell chargers, it should have a green light to indicate that the charger is getting power from the wall outlet. if the ac adapter is good, then you might need to replace the mother board as the ac port is integrated.
hope this resolves your problem.
Nov 12, 2007 | Dell INSPIRON 6000 CENTRINO...
My laptop battery won't charge
possible when the old AC adapter blew it took part of the power management circuit with it, This is the circuit that detects and charges the battery, I'm not sure whether this a seperate replaceable daughter card or whether it is part of the main motherboard. you will need to investigate this (or send it for a service)
Oct 09, 2007 | Dell Inspiron B130 Notebook
Televison & Video Logo
207 people viewed this question
Top Televison & Video Experts
