Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
Safari Browser makes the 15" PB G4 unusable
Whenever I use the Safari browser my CPU demand spikes up to 100%, most of it coming from the System side and the majority of that is sucked up by the WindowServer process. After I open Safari I can access perhaps 2 or 3 pages in windows or tabs before the problem occurs. Once it starts, I loose control of all system control - e.g. cannot select different applications from clicking on a window, or using Application Switcher, or using the Dock. I cannot get to the Force Quit dialog box or essentially anything else. Mouse movement is normal, but since all the cycles are getting sucked up by WindowServer/Safari, nothing else will respond for some time - even 5-10 minutes. Many times I simply shutdown with the power button held down, but sometimes, if I am particularly patient, I can wait it out. When I see the CPU demand duck under 100%, I can get to Activity Monitor or Force Quit and quit Safari. That will give me control again, but some windows and other operations will appear to be funky so I will save all my open documents and restart.
The PB is 1.67mhz with 2gb of memory and I do keep many windows and applications open at the same time. But if I use the Camino browser or SeaMonkey, the problem does not occur (FIrefox does not load pages for me, but that is another issue...)
  • 382 Answers
Re: Safari Browser makes the 15" PB G4 unusable
I would go info safaRI, and empty cache and reset safari, then go to software update and see if there is an update. I would also check to see if your OSX is up to date. If you are not running 10.4, i would update to at least 10.4.9. If you are running 10.4, i would get a dvd copy of 10.4 and perform what is called an archive and install.
Keep me posted.
Posted on Nov 13, 2007
0 characters
3 Points
How to connect facebook to my safari browser and get gmail delivered to my mail
Safari is the chosen browser it sounds like and Chrome is your preference for which search engine will be used. Breathe. This is a preference change that is a couple of straightforward clicks from being exactly how you want it.
1. Close everything so we limit confusion if thats ok.
2. Click on Safari at the bottom of your screen to open your Safari browser.
3. Once open, click on the word Safari at the top of your computer screen next to the picture of the apple in the top left corner. Thats the menu bar and what we want. Don't over think it and try to find something in the actual browser window.
4. When you single click Safari a list will appear with About Safari at the top. We want to select (click) the third one down that says preferences.
5. This will cause a large square box to appear in the middle of your screen. It has General centered at the top.
6. Get excited because your almost done.
7. Just below General in the first 2 square boxes are your "preferences" for your browser and search engine. They should say google or chrome for your search engine based on your question. Click the box and change the preference to Safari or whatever you would like to use.
8. You did it. Dance a jig and be a wildcat. Change those whenever you want.
If you have more problems then ask again. 40fb01b8-8524-45fc-83da-3bef201284a0.png a0d46401-fdaa-4b2d-a144-7fe9fc93d17b.png
May 28, 2014 | Apple MacBook Pro Laptop Computer with...
How do you permanently clear history on a mac notebook
Assume you are talking about your browser (Safari/Firefox/Googlechrome?) history? You need to give us a little more information, but browser history is normally cleared by going to PREFERENCES, in the browser, then PRIVACY, then follow the prompts to clear all history. (Unless you're talking about GoogleChrome, where you will need to go to their corporate servers since they have set up Chrome to harvest all information about your browsing habits so they and their corporate buddies can send targeted ads to your computer...)
Jan 04, 2014 | Apple PowerBook G4 Mac Notebook
Stopping my automatic connection to Mozilla Firefox
Each web browser has menu options to make it the default browser. If you don't want Firefox as the default, then run whatever browser you want and find the menu selection to make that the default. They usually ask when you first start them up. But I have not used Safari or Chrome, so can't tell you exactly what menu.
Sep 26, 2012 | Apple PowerBook G4 17" 1.33GHz Mac...
I have recently purchased a mac ibook G4 and unfortunatly it fell of the couch.Since then i have been having problems with Safari(internet browser).Safari and the cpu will freeze as well.Everything else...
Not sure what is going on with safari but what I would suggest is reseating your RAM on your ibook, it may have come loose. to do this have a look at it is fairly easy to do. You will at the same time as reseating the RAM you will have to remove the airport card and replace it in the same slot, this may sort the safari problem. Have you tried using another browser such as firefox. Hope this helps in some way.
Feb 03, 2011 | Apple iBook G4 Mac Notebook
How do I unblock cookies on my Mac? It won't let me sign off hotmail because it says I cookies are blocked.
The instructions are specific to the browser and OS you are using. Since you didn't specify, I will provide instructions for the Apple standard Safari browser on Snow Leopard (10.6). If you are using some other browser, such as FireFox, the instructions will be vaguely similar but not identical.
Under the Safari menu, open Preferences, then go to the Security tab. You will see a selection for "Accept cookies: Always, Never, Only from sites I visit." If "Only from sites I visit" (the preferred choice) doesn't make Hotmail happy, you will have to set it to "Always." Remember, you can always set it back later, and if certain websites still demand that you allow third-party advertising cookies, you may want to reassess whether you want to continue your relationship with those websites.
May 16, 2010 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Problems with Safari 4.0.2 browser on Mc OS X 10.5.8. Pages load slow and it crashes on occasion. Have reset and cleared cache but still doesn't work. Was not great, but now nearly unusable after...
Try dragging these files to the trash:
or just trash the application Safari, and re download it, here:
Dec 10, 2009 | Apple MacBook Pro Notebook
Telus Homepage
Launch Safari and go to the Telus login page at
Enter your name and password to get to the members' home page. Now under the Safari menu, open Preferences and click on the General tab. Underneath "Home Page," click the button that says "Set to current page."
If you use a browser other than Safari, the instructions will be similar if not identical.
Sep 27, 2009 | Apple iBook G4 Mac Notebook
Blue ball on yahoo mail site
It is not a virus,reset Safari with these steps:
1. Open your Safari web browser by clicking on the Safari icon in the dock.
2. Click on Safari in your Safari menu, located at the top of your screen.
3. A drop-down menu will now appear. Choose the option labeled Reset Safari....
4. A warning dialog will now appear detailing the items that will be removed.
5. Click the button on the dialog labeled Reset to complete the process.
Your Safari browser will now restart automatically
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 01, 2009 | Apple MacBook Mac Notebook
PowerBook g4 won't wake from sleep, won't shut off (from sleep mode). Please help!
Found this, it may help you solve your issue. Power issues on Mac G4 The PMU is a microcontroller chip that controls power functions for the computer. The PMU is a computer within a computer, as it has its own memory, software, firmware, input/output, a CPU, and more. Its function is to:
§ Tell the computer to turn on, turn off, sleep, wake, idle, etc.
§ Manage system resets from various commands.
§ Maintain parameter RAM (PRAM).
§ Manage the real-time clock.
Over time, the settings in the Power Manager may become unusable, which can result in operational anomalies with the computer. Examples include not turning on, not waking from sleep, or not seeing devices plugged into the USB and FireWire ports, among others.
Resetting the PMU is not intended for resolution of a stall or situation in which the computer is unresponsive. A PMU reset should not be necessary except as a last resort in cases where a hardware failure of the power management system is suspected. Performing a PMU reset returns the computer hardware, including NVRAM, to default settings and forces the computer to shut down.
Click on this link or copy and paste the complete link into your browser.
Thanks, Joe
May 14, 2009 | Apple PowerBook G4 Mac Notebook
Safari quitting
try running updates, re-install safari. You could try deleting cookies and clearing cache.
maybe try a different browser altogether i.e. firefox, opera etc
Jun 06, 2008 | Apple MacBook Pro Notebook
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
110 people viewed this question
Top Apple Mac Laptops Experts
 Mike M
Mike M
Louise Nadon
Level 1 Expert
Are you an Apple Mac Laptop Expert? Answer questions, earn points and help others
