2012 Nissan Maxima 3.5 S Sedan 3.5L V6 CVT Automatic Logo
A
Anonymous Posted on Feb 25, 2015
2012 maxima rear speakers not working
Just brought 2012 maxima sv and rear deck speakers no sound get sound from all other speakers
Robert A. Watson
Level 3:
  • Nissan Master 774 Answers
  • Posted on Mar 12, 2015
Robert A. Watson
Nissan Master
Level 3:
Answers
774
Questions
0
Helped
302855
Points
2079
Go to the dealer and have the unlock code reapplied. You are probably locked out, if you get no sound at all. If you get sound from some speakers, but not all... it's a wiring or blown speaker issue. Remove the unit from the dash and check the wires. If you suspect a blow speaker(s), remove one from the mounting location and move it to a known location where a speaker works and plug it in. Crutchfield makes replacements that fit your car in many price ranges.
I have a 2004 Avalon, all of the speakers (except the subwoofer) work, I noticed there is no bass and then found out the subwoofer makes no sound, does anyone know what might be the problem?
Toyota Avalon JBL Speaker Subwoofer Foam Repair 86160 ...
? 18:34
https://www.youtube.com/watch?v=vDHEbiyBt9I
Jul 16, 2012 - Uploaded by Simply Speakers
Toyota Avalon JBL Speaker Subwoofer Foam Repair 86160-AC180 .... Luckily you don't have to remove the rear deck to get at the subwoofer, ...
Removing rear subwoofer / rear deck - Toyota Nation Forum : Toy
1helpful
I have a 10 maxima and my rear deck speakers don't work there is no voltage at the speakers at all I have the s model maxima I heard that you have to get a code applied to it but not sure any help plz
Hi Rich
The usual cause of this is that the fader has been turned to front speakers only. Give that a shot and I hope it helps you out.
-Steve
Pull the unit out from the dash and check the wires first. Most aftermarket untils have a two pair of holes on either side, use nails to insert into the holes and press to release the unit after you get the fascia off. Check the wires carefully. Try taking one of the rear speakers out and plug the connectors from a door panel speaker on it to see if the speaker is good. If the speakers are bad, replace them. Crutchfield sells replacements you know will fit properly. Check the ground wires too!
Nissan Maxima SV 2013. Noisy sound when turn ON/OFF A/C - driver side
Mode door may be dragging a bit. As long as everything works, I would not tear into it. Its a big job to repair.
2010 nissan maxima fuel filler door release mechanism
My gas door will not open on my 2012 Nissan Maxima.
It looks to be pushed in too far
Nissan Maxima 1997 Stereo not turning on at all!!
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose
Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
Factory rear speaker wire colors
you could have wires coded with a red stripe this is usually pos . speakers will work with wires either way as they are only running the cone electromagnet .
I cut the plugs from the facturay harness for the radio now i am trying to hook everything back up and do not now what colors from the harness goes to the stero. then what the other colors go to that are...
Here are the stereo wiring colors.
1995-97 Nissan Maxima Stereo Wiring Constant 12V+ Pink/Blue Switched 12V+ Blue/Black Ground Vehicle Chassis Illumination Red/Blue Dimmer Red/Orange Antenna Trigger Black/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Matching wires for a car radio in a nissan maxima
Constant 12V+ Green/Red Switched 12V+ Pink/Brown Ground n/a Illumination Red/White Dimmer n/a Antenna Right Rear Front Speakers 5 1/4" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 5 1/4" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
