Question about Lands Phones
Uniden 900MHz phone model EX17960A
I don't have the manual and I want to program the phone with numbers for speed dial.
  • Anonymous Feb 25, 2008
    have lost manual for uniden model 84047123 and would like to program new numbers
  • joycem2008 Dec 16, 2008
    I have the same problem but my model is EX1376. so the posted solution does not work for me. Any idea?
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
Each pause counts as a digit.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
number has been stored.
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
will return to standby mode.
Dialing a Stored Number
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
beep rapidly, and the phone will not dial.)
Posted on Apr 13, 2008
How to enter a speed-dial phone # I have a Uniden 5.8GHz phone system and want to know how to enter a programmed phone number for speeddial
Since you declined to specify the model of your Uniden phone, select it from the list beginning here to download the manual.
Sep 25, 2011 | Uniden 5.8GHz Cordless Phone
I programmed a speed dial number, how to I dial
Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Oct 24, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
I have a UNiden 900mhz extended range and lost the guide for resetting modes, time, number of rings, etc. Can you give me a quick guideline?
just look up online Uniden cordless phone Owner's Manual 2.4Ghz model EXAI 2224 series. It's free and lists all the commands needed for your Uniden 900mhz phone. page 1 to 68 just like the same one that came with the phone.
Sep 05, 2009 | Uniden Cordless Phone exai398i
How do i program my 900mhz uniden freedom phone
Go to Look in customer service/manuals
Jan 22, 2009 | Uniden Cordless Phone
Setting the speed dial numbers.
When phone is on standby press memory-the talk led lite should flash. enter the phone # you want to store then push memeory again. Select the speed dial # you'd like to use for this phone # (0-9) then you should here a tone indicating it was successful. Let me know if this works for you-it should!!
Nov 12, 2008 | Uniden Cordless Phone
Speed Dial for a Uniden Model DCT648-3
Do you have a copy of your owners manual? If not, here is a link to a pdf format version of it, from the Uniden website:
Speed Dialing
If you store a phone number in a speed dial memory location (10 locations: SPD1 - SPD0),
you can use the speed dialing feature. When the phone is in standby mode, press and hold a
number key (0-9) associated with the speed dial until the phone number appears and then
press talk/flash or speaker. The number stored in the speed dial (SPD1 - SPD0) is dialed.
Nov 30, 2007 | Uniden DCT648-3 Cordless Phone
Rocket dial
how do you program and delete rocketdial?
Nov 04, 2007 | Uniden Cordless Phone
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Lands Phones Logo
849 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
