Question about LaCie 250GB Ext/Firewire 7200 250 GB Hard Drive
Lacie drive won't mount
My Lacie drive won't mount now that I have installed the new OX 10. What can I do?
I solved the problem. It was a power supply problem. It seems after searching boards on the net, this is a common problem with the lacie hard drives. Just replace the power if your hard drive is clicking and not mounting. I think many people must be throwing the drives away thinking they are lost when it is just the power supply. Try this first before trashing it or spending a lot of money on data recovery programs/
Posted on Sep 23, 2009
  • ESNOEL Dec 26, 2010
    Actually i had the same problem after alogic pro session with my new lacie and decided from the sound of my hard drive it sound well and it is trying to mount on my mac osx but it could not
    so i connected it to windows and there it goes itshowed up using mac disk i was able to read the files well and correct errors
  • bigluttz Mar 13, 2011
    how long did it take to mount the drive did it stop clicking
Solution number two TOTALLY works. My drive began blinking and clicking, and eventually failed to mount. I switched the power cord from a working drive to my "busted" one- and it worked perfectly again! Now I just need to order a new power cord from LaCie...
Thanks guys!
Posted on Oct 16, 2009
    New Friend:
I've had the same problem with the 500GB LaCie drives. Both seemed to stop working at exactly the same time. Turned out to be that one of the power supplies had gone and since I only ever had one plugged in at a time, I was using the same (busted) power supply for both.
Check your supply, don't try anything else till you've tried this
Posted on Feb 08, 2010
    New Friend:
I too replace the power supply and up she boots, hurraahh. Thanks for the comments above as I had also tried my backup of the backup drive using the same duff power supply and thought that both drives had failed!!!!
Posted on Sep 09, 2010
    New Friend:
Gotta say- both drives went down and I thought power supply was the only common factor. Came here and read this was probably the case. Swapped it out for the one still in the LaCie box and everything came back just like it should. 5 minute fix. Now if someone could explain to me why their power supplies keep failing...
Posted on Jul 22, 2010
Ive solved the Whole Lacie wont mount problem.... Thanks to Lacie support center, Best Buy, The internet and several Tech shops I took my crashed lacie d2 quadra 500 GB hard drive to for help when it crashed. They didn;t help and none of the stuff I bought helped either. Here is the solution: Take any of your crashed lacie Hard drives (That are clicking and making a noise to a Windows OS) FOOTNOTE: NO MATTER WHAT ANYONE SAYS, YOUR LACIE HAS NOT CRASHED AND DOES NOT NEED DATA RECOVERY$$$$$$$$ Take it to a Windows (XP worked on mine) install your lacie one button disk, after its installed properly, Run the lacie one button recovery by clicking the blinking and clicking switch on the hard drive the program will come up and show the Lacie Hard drive. Go to windows control panel and run add hardware program and search once. (if it hasnt mounted it will not find it) just let the search go through once and after it says can-not find hardware leave it open. Go to My Computer and open it, keep the window open that shows all of your drives. Wait about 4-8 hours depending on what you have going on (go to the movies or go to sleep) and come back and your lacie drive will be mounted. (THIS IS NOT THE LAST STEP- DONT GET HAPPY YET) This is whats going to burn your attitude to a new level. The Lacie Hard drive is SUPER un responsive. I advise opening just the main window and taking a look at all the folders and files you have on them. ( i solved mine by simply erasing the Video files. Final cut pro cache folders etc.) if you use your hard drive for things like editing video and audio then more than likely your drive is slightly corrupted (don't get angry) this does not mean its trashed, it means that there is a problem with file structure and a single or several files confused the hard drive. Once again your lacie is not trash. I used mine for video editing in Final cut Pro, and Audio in Pro Tools, among other things like saving photos and software, etc... Just take the time to simply delete what you know you dont need.. or even better, format the entire drive and it will be like new. Another step you can take in mounting your Lacie is to download Mac Drive 7, install it on a PC- not MAC, this process WILL NOT work on a MAC (none of these steps will work on a mac- Trust me, not matter what these nerds say, dont believe that it will- its going to cost you.) Install the Mac Drive 7 on a pc, run the Error Check and repair function and it will take about an hour depending on what you have on your drive and how many errors are found. and It will fix the drive. As stated previously - these steps will ONLY MOUNT YOUR DRIVE. Access to the files and folders on your drive will be very unresponsive. Basically if you plan on copying a movie to your desktop forget about it. 30Mb would take about 2 hours. 6Kb took close to 4 mins to copy from the lacie. You wont be able to back it up so forget about that too. Just follow the begining steps and find out what has done this to your Lacie (you know what it is!). As stated previously- I used my LACIE D2 qudra 500 GB Hard drive (that is only 6 months used) for average things like downloading, uploading, saving, etc... the same things you do, Plus I ran Final Cut Pro, Pro Tools, Logic Pro, and a S**T load of other programs on this drive and what confused or "Corrupted" my lacie and made it BLINK, CLICK, and make STRANGE
Posted on Mar 19, 2008
    New Friend:
Yes, replaced the power supply (the brick) at the Apple Store, and the drive mounts fine, no more blinking, no more clicking and the data is fine.
Now, need to find out where I can buy a replacement Lacie power supply.
Posted on Nov 09, 2009
    New Friend:
  • 4 Answers
Lacie drive wont mount problem is experienced by computer users when the files are corrupted. In order to overcome with this issue you need to make use of third party lacie drive recovery tool. Before using this software you need to format the hard drive. After that in order to restore the lost data you should make use of third party lacie disk recovery application.
You can also follow link mentioned below in order to solve out this issue:
http://www.laciedriverecovery.com/laciedriverecovery/lacie-hard-drive-wont-mount.php
Posted on Oct 14, 2011
SOURCE:
My cpu won't recognize my LACIE Minimus Drive. I have no Setup Assistant and I need the info locked on the drive. What do I do?
Go download EASEUS Partition Master 5.8.1 Home Edition (free). I've found it very useful to check and often repair drives that won't mount.
Feb 26, 2012 | LaCie 1TB Minimus USB 3.0 Desktop - 301961...
Mac doesn't read the drive. Time Machine reads 'delayed' then 'failed' because it can't read drive. Won't backup. Drive doesn't show up on screen.
- Open the disk utility application found in the applications folder, then open the utilities folder
- See if it detects the LaCie drive by looking on the right hand side where it lists all the available drives including your optical drive
- If it is just greyed out you might only need to re-format the drive or possibly repair the disk.
- If it does not appear in this list the drive has most likely failed and is not economically repairable
May 17, 2011 | LaCie Rugged All-Terrain (301017) Hard...
I have a LaCie Rugged Drive, with multiple interfaces (USB, Firewire 400/800). Firewire interface works fine. When I plug the drive in the USB port, it won't mount (MacBook Pro OS X), and a faint beeping...
the problem is that your lacie drive operates using the NTFS (New Technology File System) under USB which is the standard file system of Windows. Apple mac is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac if you wish to use it via the USB connection.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Jul 31, 2010 | LaCie (300951U) 500 GB Hard Drive
The icon for my lacie exyernal hard does not show
Here's two suggestions. (If your using Mac OS X 10.x)
Make sure external hard drives are to be shown by clicking "Finder" in the menu bar then "Preferences" and under the "Sidebar" section selecting "External Disks".
Also check that the hard drive is mounting by opening "Disk Utility" by first opening the "Applications" folder then the "Utilities" folder and double clicking "Disk Utility" and in the left sidebar checking to see if your external hard drive is listed as one of the mounted drives. Hope this helps, don't forget to comment/vote if this helped. Thank you.
May 30, 2010 | Apple Computers & Internet
First time trying and i cannot access my data. This is the first time I tried to pull it up.
USB is very finnicky. Shut off your computer and external drive. Unplug the USB cord from one end (which ever is easiest). Turn on your computer. When windows is up, plug in USB cable. Turn on USB drive. Windows should recognize the USB ox and drive and attach the extra drives. But, you must have windows millenium or newer. Or you will need USB drivers for the external USB box.
May 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie hard drive won't turn on
My 1TB Lacie suddenly won't power up (no sound, no blue light). It turned out that I might have worn out the on/off switch over the seldom-use 4 years of usage. I push and flip the switch multiple times, and the Lacie came back to live and mount normally. I will just leave it at the On setting and simply pull the power cord when i want to switch it off.
Obviously, Lacie failed to do QA on the on/off switch because my 4 years usage did not totalled to more than 10 on/off per month.
Mar 09, 2009 | LaCie (301074) 80 GB Hard Drive
Cannot find the lacie driver on my mac
Chances are the drive is bad. Try taking it to another computer- if it doesn't work there, then the prognosis is poor. Data recovery services are available, but pricey.
Feb 05, 2009 | LaCie d2 Extreme (301033) (301033A) 160 GB...
Lacie will not mount
hmm..power it down...wait a minute or three..try again..
may need new set of drivers..
Mar 28, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
Lacie hd problem
This is a pretty old thread, but I just figured out the work-around for my Lacie drive with the same symptoms. I took the Lacie case apart to find a pretty standard 3.5" Seagate Barracuda drive inside the case. If you pull the actual hard drive out of the box, you can either purchase a new external hard drive adapter box ($30-80) or install it into a tower computer. I installed it into an older G3 tower and it mounted right up. I decided it wasn't worth investing in a six year old hard drive, so I will be purchasing a new drive and pulling the data off the old one.
Mar 05, 2008 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Open Questions:
SBCglobal MAil HeLpliNe NuMbER {1=855=536=5666}#[email protected] TOLL FREE Sbcglobal Technical Support Team Solve{1=855=536=5666}#O{1=855=536=5666}#[email protected] All Type Issues. We, at SBCglobal customer services, offering complete{1=855=536=5666}#[email protected] C solution that you{1=855=536=5666}#[email protected] NEW JERSEY have been looking for.{1^855^536^5666}#[email protected] ALABAMA We serve the better satisfaction with cent percent. Our Sbcglobal email instant technical support includes dealing with connectivity{1=855=536=5666}#[email protected] NEW MEXICO problems, Sbcglobal email password recovery, and complete{1=855=536=5666}#[email protected] TECH SUPPORT support related to your Sbcglobal email account. If Facing issues {1=855=536=5666}#[email protected] SUPPORT NUMBERin Sbcglobal email then Contact on Sbcglobal technical support phone number to fix the technical issues via expert technicians.Sbcglobal customer service excutive are well expert and help their customers 24x71^**********^ PROBLEMbcglobal Technical Support Team Solve All Type Issues. We, at SBCglobal customer services, offering complete solution that you have been looking for. We serve the better satisfaction with cent percent. Our Sbcglobal email instant technical support includes dealing with connectivity problems, Sbcglobal{1=855=536=5666}#[email protected] MINNESOTAemail password recovery, and complete support related to your Sbcglobal email account
Sep 18, 2019 | VIA Computers & Internet
SBCglobal MAil CuStOMeR Service PHoNe {1=855=536=5666}#[email protected] CUSTOMER HELP Sbcglobal Technical Support Team Solve{1=855=536=5666}#O{1=855=536=5666}#[email protected] All Type Issues. We, at SBCglobal customer services, offering complete{1=855=536=5666}#[email protected] C solution that you{1=855=536=5666}#[email protected] NEW JERSEY have been looking for.{1^855^536^5666}#[email protected] ALABAMA We serve the better satisfaction with cent percent. Our Sbcglobal email instant technical support includes dealing with connectivity{1=855=536=5666}#[email protected] NEW MEXICO problems, Sbcglobal email password recovery, and complete{1=855=536=5666}#[email protected] TECH SUPPORT support related to your Sbcglobal email account. If Facing issues {1=855=536=5666}#[email protected] SUPPORT NUMBERin Sbcglobal email then Contact on Sbcglobal technical support phone number to fix the technical issues via expert technicians.Sbcglobal customer service excutive are well expert and help their customers 24x71^**********^ PROBLEMbcglobal Technical Support Team Solve All Type Issues. We, at SBCglobal customer services, offering complete solution that you have been looking for. We serve the better satisfaction with cent percent. Our Sbcglobal email instant technical support includes dealing with connectivity problems, Sbcglobal{1=855=536=5666}#[email protected] MINNESOTAemail password recovery, and complete support related to your Sbcglobal email account
See all LaCie 250GB Ext/Firewire 7200 250 GB Hard Drive Questions
LaCie 250GB Ext/Firewire 7200 250 GB Hard Drive Logo
19,993 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
