Question about GE WBVH6240F Front Load Washer
Washer load became imbalanced and forced door open, now cannot close door, lock stuck and washer will not run
My whirpool duet ht front loader washer load became imbalanced and
walked a bit, the door came open during this and now the door will not close all the way. Its like it is stuck in the locked position.
I have unplugged the machine, no change. I have got the machine going by
putting pressure in the lock area and then hitting the pause button, but the
lock will not unlock which will not allow door to close properly to use
    President:
  • 1,294 Answers
Perhaps you have to change your lock, this is a sensitive point & will affect the smooth operation of your machine. Re. the inbalance, you hv to screw up & lock the front 2 legs (with check nut), adjust the front legs (screwed up) only to see if the machine does not move during wash/spin.
Posted on Nov 29, 2007
  • prem mathew Nov 29, 2007
    You do not (never) open door during operation; and even after the machine stops after the wash is complete, wait for a couple of minutes. People dont pay atten to this & problems occur....
    Check the door switch area to see if any wires have come loose, tighten/refix. Plug off the wall first, remove top of machine.
Why is my duet whirpool washer door not cycling through. It seems locked open
Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism. I found this at the Appliance Guru website.
Jul 27, 2014 | Whirlpool Duet GHW9150P Front Load Washer
What is the code to open a Whirpool washer machine Duet HT
Switch on the washer. Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have an F26 code and my washer won't do anything and cannot find code in the manual what does it mean? It's a whirlpool duet ht
Hi, This F26 error means "door switch error" If the door has not been opened for three consecutive cycles or the door switch is open while the door is locked for more than 5 seconds
Do the following to fix the problem:
Open and close the door
Verify CCU operation by running a Diagnostic test or any cycle
Push the door and check if its completely closed
Apr 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My clothes are stuck in my front loading whirlpool washer. How do I open the door manually
The following link explains how to open the door manually on a Whirpool Duet:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
GE WBVH6240F Front Load Washer Logo
386 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
