2005 Mazda MAZDA3 Logo
d
david williams Posted on Feb 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replced battery on my 2005 mazda 3 tried to enter but not right one so now has err on the radio/cd player is a mazda original can you help me plz
Need to unlock err code plz the serial number is 04h1b3290 hope this is of help D Williams
David Harrelson
Level 3:
  • Mazda Master 5,456 Answers
  • Posted on Feb 24, 2015
David Harrelson
Mazda Master
Level 3:
Answers
5456
Questions
17
Helped
1099652
Points
15442
I cannot enter cd in cd player in mazda 626
If the radio works, there might already be a CD in the player. If the radio is NOT working, check the fuse. Another option would be to disconnect the battery for a minute, or so, to reset everything. Just some initial thoughts that may or may not work.
Need code for radio/cd player for mazda ts2 o4 plate
People on ebay can get the code for 99p just need the serial number for the unit. Ive used these people before worth 99p
2answers
Hi there i have a mazda 6 1800 cc witch i bought on 2007. the cd player is locked.now there is a message err on the panel do gou know how i can unlock this? thanks a lot stelios peratinos
try dis-connecting the battery for 5mins which may allow you to re-install a code but you will need to get correct code as if keep typing anything it will lock again.
2answers
After my husband changed the battery in my STS, the CD player will not work. I have 3 CD's loaded in the player. It will not play or eject.
You need enter the unlock CODE for extract your CDs; check in your owners manual (any label in the last page .
THEFTLOCK is designed to discourage theft of your vehicle’s radio. The feature works automatically by learning a portion of the Vehicle Identification Number (VIN). If the radio is moved to a different vehicle, it will not operate. If the radio is removed from your vehicle, the original VIN in the radio can be used to trace the radio back to your vehicle.
With THEFTLOCK® activated, the radio will not operate if stolen.
Fot other details can check 2005-Cadillac-STS-Owners-Manual
Hope helps.
CD ERR 1
Have a 2005 Freelander and the battery died. When I re-charged the battery, the CD changer had a CD ERR 1 message. Could not eject or load a CD and the radio worked. I turned off the radio and pulled off the cover on top of the CD changer. I removed the two screws that hold the frame around the CD changer. I turned the CD back on and the CD went through a test on each CD. I know this solution might not work for everyone, but it worked for me
1helpful
3answers
After Changing my Battery my CD Player has a "Code "Flashes Now Err Fashes
When you bought the car your dealer must have given you that code or you can call them and let them know your registeration details they will give u the code for free all you have to do is to give them your details.
Good Luck !!!!!!!!!!!!!!!!!!!
1helpful
Err on CD player....2005 Honda CRV
it sounds like it may have a bad laser or even dirty try removing the cover and gently cleaning the lens if you dont feel confident i would suggest you put it in for a repair usually removing the battery lead for up to half an hour will reset the system and put it back to its original state but its suggested if it doesnt then its internal usually the laser.
1helpful
ERR Displayed on CD Player
try disconnecting the battery for several minutes then reconnect this may act as a reset and bring the stereo back to its original state
Top Mazda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mazda Expert? Answer questions, earn points and help others
