Question about GE JGRP17 Gas Single Oven
Electric starter gas oven model jgrp17 won't heat
I ahve a GE JGRP17 gas wall oven. The broiler works, but the bake burner appears to be out. It satared working for about 45 mins and then all of a sudden went cold. Any help appreciated. Ed
  • 1 more comment
  • eveready Dec 09, 2007
    water put out my ignition. how can i relight it.
  • Anonymous Dec 31, 2007
    My oven is the JRP17W and the broiler heats but the oven will not bake. It started Christmas morning turned it on to 350 degrees put the ham in and checked it later to find that it was cold and not cooking. The broiler does work no problem.
  • Lowell Schultz Mar 14, 2008
    After the GE JGRP17 oven was put through the self clean it won't bake. I have determined that the ignitor is OK (measures 143 Ohms) and there is no 115 Volts at the ignitor wires when oven is turned on. I suspect that there is a thermal breaker somewhere but can't find it. Please help.
    Lowell
  • 25 Answers
More than likely your glow bar ignitor has stopped working or at least pulling enough amps to open the safety valve. The floor of the ovens come out may have a couple screws toward the back. take the floor out if a diffuser is on top of the burner remove it. the glow bar ignitor is mounted on the burner turn the oven on and watch it should glow bright red and in about 30 secs open the gas safety valve. If it does not glow you may want to verify power to the ignitor, more than likely the ignitor is the problem. If it glows but does not open the safety valev still replace the ignitor not pulling the required amps to open the safety valve. just put a little dish soap on the screws to the ignitor to help from srtripping them out
Posted on Feb 23, 2008
Oven does not heat, no sign of a lit burner but broiler works. Suggestion to check ignition system would be appreciated. thanks Russ and Sherry Model 17bew5bb sn ff642442d
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 15, 2010 | GE JGRP17 Gas Single Oven
Gas in oven wont come on,burners and broiler ok, oven light comes on but oven won't come on,electrical connections ok, checked
this is a 2 burner oven with 2 ignitors . the bake ignitor is too weak to light the burner . replace it and the bake should work properly .. mm
Jul 13, 2010 | GE JGRP17 Gas Single Oven
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Jan 28, 2009 | GE JGRP17 Gas Single Oven
The problem is our over which I think is a GE JGRP17 Gas Single Oven based on descriptions on this site, the stove burners and broiler are working but the regular oven won't work, the igniter doesn't glow...
the problenm is in the ignitor. there is a possibly a break in the ignitor to where there is no continuity in. I would buy a new ignitor and then shut off the gas to the oven and replace the ignitor. That will solve your problem. Have a Merry Christmas and thank you for using FixyA!!
Dec 25, 2008 | GE JGRP17 Gas Single Oven
Gas Oven doesn't work under 450 degrees
most common issue is a bad bake ignitor, easy fix, probalby about $75, located on the side of the bake burner, simple to replace a few screws and 2 wires
Nov 17, 2008 | GE JGRP17 Gas Single Oven
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Gas stove
The JGRP17 (not a full model number) does not have a pilot light. It uses glow bar ignitors. Watch the burner at the top of your oven when you turn on broil. After a short time the glow bar ignitor begins to glow, and a short time after that the broiler burner should ignite. The same thing should happen with the oven burner under the floor of the oven when you attempt to bake. If the igniter does not glow, or glows and burner does not light, replace ignitor. (looks like part # WB2X9154)
Sep 04, 2008 | GE JGRP17 Gas Single Oven
Oven does not Bake, Heat Up
Replace the oven glow bar igniter. If you post an exact model number (located on sticker behind lower drawer) I can give you a part number.
Sep 02, 2008 | GE JGRP17 Gas Single Oven
GE JGRP17 Gas Single Oven Logo
634 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
