All the other voltages generated by the SMPS too should be checked. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Schematic diagrams along with voltages are given. Refer it, and check all of it.
SOURCE: Crt standard hisense tv no power fuses are not
Sometimes is possible. Because, when the transistor shorts, the small value load resistor connected to its emitter might blown up before the fuse.
your problem is that your output is less than normal
first you isolate h/output from power supply if it comes to normal(115V).
then problem in h/output stage
for that you check
h/output,cap & diode in flyback section & flyback transformer.
but power output is still 50v then problem in power supply for that check oscillator ckt & switching output.
good luck.
