SOURCE: reverse on kenmore sewing machine 385
I recommend that the machine be serviced by a professional but if you're handy it may simply need cleaning around the reverse cam. To do this place the machine on it's back. You'll need to access the rod that drives the feed dogs and cam mechanism by removing all screws holding the bottom plate of the machine. Remove the bottom plate. Note that when you push the reverse button, while turning the wheel a thin rod moves left which allows a plastic cam mounted to the cam rod to also move left and engages the feed dogs in reverse. If the cam is not moving enough or if too slow, it may be that the rod and cam need cleaning and lubrication. Clean out all lint and lubricate the cam where it moves on the shaft. Try to get it to move more freely without forcing it. When done replace the bottom plate. I just repaired my wifes machine and this solved the problem. Hope it helps.
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
SOURCE: I need a manual for Kenmore sewing machine 385 11703700
you can go to www.kenmore.com and then click customer care. There is a phone number to call for a replacement manual.
SOURCE: Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
The winding sound is the rubber O-ring against the spinning pulley (back
of hand wheel) - do not let this continue, it will wear out the O-ring.
I had the same problem and I found the shaft bushing of the winder dry and needed lubed. Use oil or spray lithium grease and it should work fine. Spin the bobbin shaft by hand (not the hand wheel) to get it freed up after oiling.
You can oil from the top and should take off the side case to clean the excess oil from the O-ring. The shaft bushing is a tight fit and any dry oil will get sticky and prevent winding.
