Question about Amana NDE2335AY Electric Dryer
Help with odor
Foul smell, like rat crawled inside dryer (somewhere) and couldn't get out and died
I have had this happen 2 times. Chipmunks discovered the outdoor vent that exits through our basement window. They crawl in and suppocate in the link. You need to remove the vent hose.... take it outdoors and empty out your dead critter!
THEN, find some way to keep it from happening again.
Posted on Nov 13, 2007
Rat chewed wire to ignitor
replace ignitor assemblyand set a trap for the rodent, penutbutter on a snap trap works best,no posion and it wont crawl inside the walls to die and smell up the joint PSthe bigger the rat the bigger the trap
Mar 07, 2014 | GE 30 In Freestanding Gas Range ...
For some reason my dryer makes everything smell like skunk
This may sound crazy but I did a service call on time for a terrible odor found a rat had crawled in thru the exhaust tube and died.
Feb 06, 2014 | Dryers
Rat urine smell in crawl space
Simply place one of the Clearoma rechargable gel-paks in the crawlspace and allow it to destroy to foul odors and also force the rats or rodents to leave the building, because of the product scent.
Dec 04, 2013 | Clearoma Gel-Pak Quart
Odor
if you have a bad odor,pull off the vent line from the back and see if an animal is dead there,i've found dead birds,mice and a possum,in the blower wheel of some dryers,they get in from the outside hood,once they get into the vent line and slide down they can't climb back out or if the dryer is running the wheel does a job on them.also if you had some painting or staining done this also can make the dryer smell bad.this is going by what i've found when someone complains about an odor in the dryer.hope this helps,one more thing if the motor is overheating from the dryer not being cleaned out it could have like a shellac smell,you might have to take the dryer apart to see what's stinking or it could be something near the dryer,when the air is heated in the dryer it makes the smell worse but if you find waht is causing it and remove it the smell will go away,if it is from a dead animal you can wash down the area with soapy water,you don't want to use anything with a strong smell because your clothes will smell of that when the dryer heats up.what does it smell like?
Apr 13, 2013 | Maytag Atlantis MDE6400AY Electric Dryer
Dryer is not drying- wet lint in the filter
Maybe you have a dead animal, (mouse,rat etc) inside of unit. They could have died whilst chewing the wiring, hence the no heat problem. Take off the panel on the back of unit or tip it on it's side. You should be able to see the inner workings and anything else. If not, buy a new dryer, this one must be costing heaps to run.
Dec 14, 2011 | Dryers
Foul odor
check the back of the dryer where the heating element is or underneath of it to see if a mouse is in there they like the warmth if it is located in the basement and could of crawled up there and died
Dec 05, 2010 | Dryers
After wash there is terrible smell. have cleaned filter and powder tray.could there be residue somewhere
front load washers are known for foul odors, There are many products available to eliminate these odors. Affresh and smellywasher are two products for removing the odor
Nov 10, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Bad smell
clean it with baking soda hot water and hair dryer
Feb 27, 2009 | Frigidaire FRT21H8 Top Freezer...
Rat in dryer vent
You can most likely fet a diagram on sears.com. Go to the parts section and put in your model number and it will let you access diagrams.
Nov 20, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Very bad odor in Maytag refrigerator
There is a very bad smell from the bottom of the refrigerator . There is a pan under the refrigerator with a very bad smelly Liquid , How can I clean that pan I couldn`t pull it out ? Thank you
Feb 20, 2008 | Refrigerators
Amana NDE2335AY Electric Dryer Logo
172 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
