Question about HP ScanJet 3200C Flatbed Scanner
Jamming The unit jams while warming up. the mechanical arm seams to get stuck on something. slide gets stuck in the machine and i have to press the green button on top to get it out through the top of the machine rather than have the arm pull it out into the magazine. Scanner acts as if it is stuck. I have downloaded the latest updates for XP home edition, but it still doesn't do anything but buzz.
    President:
  • HP Master
  • 2,022 Answers
See if you are able to open the cover if you success then use any lubricant oil and apply on scanner head steel rod .
bye
Posted on Nov 16, 2007
I can't get a 1/4" seam allowance to sew on my eden rose without jamming the bobbin for quilt piecing .
perhaps a 1/4" seam is a bit too small for it to handle. Try a slightly larger seam allowance. On a bit of scrap fabric.
Jan 22, 2018 | Sewing Machines
Canon printer error code 6A81
Solution 1: This is a purge unit error.
There maybe something jamming the purge unit or just a absorber out of place which is picking up on the carriage preventing it from moving correctly.
Try to move the carriage away from the purge (its where the printhead/carriage parks its self on the right side of the machine) with no resistance then you can shine a torch into the machine and look at the purge unit.
There maybe crumpled paper jammed in the purge.
If all looks well, the purge unit may be defective and had to be replaced.
Solution 2:
The wiper on the purge may have stuck. It slides back and forth and they have been known to stick.
Push it with a long screwdriver to see if it moves.
Solution 3:
Something is blocking the printer inside. It could be a paper jam or a foreign object.
Check using a flashlight, to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen.
If there is nothing obvious, unplug the printer power supply.
Dec 02, 2015 | Canon PIXMA MX882 Wireless All-in-One...
Threads jamming the bobbin case on elna sewing machine
Probably unevenly wound on the bobbin. Or tension needing adjusting, be careful to note where tension spring started before adjusting and do in very small increments.
Perhaps the spring has some fluff stuck on it and thread cannot slide through easily. Take out bobbin and clean
Nov 02, 2015 | Elna 2007 Mechanical Sewing Machine
Sewing machine is jamming on first turn permanently
Your bobbin may be in backwards. Is it possible to put it in either way?
Mar 01, 2014 | Singer Co Singer Talent 3321 Sewing...
Exit jam
have the machine perform a paper path test with just 1 copy to see if this jams then have it path test 5 prints to see when it jams- if its only jamming when more than one sheet is being printed then the fault lies with the paper pick up ( you may notice a longer delay for first print)
the machine will attemp to feed three times before failing as a jam
if the machine is printing more than one sheet then the jam appears just before the tail end of the first print exits the fuser (fixing Unit).
clean or replace the feed rollers.
if the jam happens on every print and the code is 13:02/3
then paper pass sensor arm 2 has stuck (look on you tube to resolve this search for lj4200 13:02 jam)
hope this helps- if you are still unable to get the machine working and your willing to pay then I would suggest Belmonte Buisiness machines
are a good company to deal with they are on 0161 480 5556 and can call out anywhere in the UK
Jan 26, 2014 | HP LaserJet 4250n Printer
Unit fell on the floor and now gets stuck while "Reading Disk .." after hitting play. Can hear the mechanism start and stop continually but never gets past the reading disk stage. Perhaps...
1. Open unit as if you were loading a disc.
2. Locate laser lens and sliding lens assy.
3. Take a non-conductive material (wood, plastic) and try moving the laser assy. along the track.
NOTE: you may have to be a bit heavy-handed to make the laser assy. move.
4. Move it in one direction but only far enough to free the jammed laser mechanism
5. Reinstall a DVD and press "play"
Nov 08, 2010 | Panasonic DVD-LS86 Portable DVD Player
My dcp 150c printer has been jammed for weeks, i have done everything it said in the manual but it won't unjam
This Brother printer could have a piece of paper stuck in it. When a paper jams, assemble the jammed page pieces to make sure all the pieces came out.
A jammed paper can also knock loose the paper detect arm that senses a paper in the machine. This detect arm is usually near the platen (The roller the print head prints against) to detect paper in the machine. If this arm is stuck, it could be sensing paper when there is none.
Rubber paper rollers should all be cleaned with rubbing alcohol or a mild soap solution (I use Windex) to prevent feed jamming.
Mar 28, 2010 | Office Equipment & Supplies
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
Evere 6th or 8th frame james very frustad
I have a slide jaming problem and got this from ELMO support. I have not tried it as yet. I am using 80 slide carousels.
If the unit is jamming like the way you described it may be that the arm needs to be adjusted. If you hold down the SELECT button and turn off the unit while still holding for about 20 seconds at the same time as holding up the arm, you will be able to get to a screw that can adjust the height of the arm.
Dec 20, 2008 | Elmo Projectors TRV-35H Slide Projector
PRINTER SAYS PAPER JAM 23 ..
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
thanks J
Jan 11, 2008 | Samsung SCX 4521F All-In-One Laser Printer
HP ScanJet 3200C Flatbed Scanner Logo
228 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
