Question about InFocus ScreenPlay 7205 Multimedia Projector
White vertical lines in image w/ 2 inch black bar horizontal.
These thin white lines are vertical on image and are in proportion to each other. I tapped on the unit and the lines went away then came back shortly. There is also a 2 inch black bar horizontal through the image as well. Please help.
  • 2 more comments
  • Smittty Nov 12, 2007
    This is an Infocus Screen Play 7205
  • danboz Nov 24, 2007
    I have thin vertical lines in an infocus In24. No horizontal bar however. The lines come and go with jiggling the projector. Any solutions? Thanks,
    Dan
  • compleks Dec 15, 2008
    looks like were all on the same boat. :(
  • Anonymous Dec 28, 2008
    I have the same problem....vertical lines that appear and the disappear. fran
  • 2,237 Answers
The black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Posted on Dec 29, 2009
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Thin black vertical lines in infocus projector screenplay 7205
normally, i'd say av solutions in ny, but they don't ship out of country. try www.projectordoctor.com.
Jan 22, 2010 | InFocus ScreenPlay 7205 Multimedia...
No picture on magnavox 32MT6015D
THAT THIN WHITE LINE IS YOUR HORIZONTAL LINE MEANING YOU ONLY HAVE THAT. THE GOO NEWS IS YOU HAVE HIGH VOLTAGE MEANING YOU ONLY NEED VERTICAL TO FIX IT.. I WOULD REPLACE THE VERTICAL TRANSISTOR OR CHECK FOR ANY BURNED RESISTORS ON THE VERTICAL SIDE
Feb 22, 2009 | Philips Magnavox 32MT6015D TV
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
VERTICAL WHITE LINES
I just read a post that said tap on the top and the line will go away. I tried it on mine and it worked! I had to tap it fairly hard. I just kept tapping harder and harder on the plastic in front of the buttons and voila! The vertical white line disappeared!
Oct 07, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Thin horizonal line in middle on dark screen
The several thin white lines at the top of the screen is the warning that the vertical output IC is not getting the boost voltage it needs to run correctly. The IC cannot operate for long like that and shorts out inside, which is when the vertical collapses altogether and you get the thin white line through the center of the screen. The good news for your son is that he had nothing to do with that, and it has nothing to do with the cable F connector. The set needs to be serviced by an experienced tech who will restore the boost supply and replace the vertical output IC, and when I do that I charge $75 but techs in your area will vary, so be sure to ask around.
Jul 26, 2007 | GE 24GP653 24" TV
Thin Bright line is all I got on the tube
Sounds like a capacitor and/or the Vertical amp Ic has gone out in the set. Maybe a bad solder joint. Depending on where you live, the cost of repair could be between $100.00 to $150.00. Kill it or what? What would Braveheart do. FFFRRRREEEEEEEDDDOOOMMMM
Mar 18, 2007 | JVC AV-27850 27" TV
InFocus ScreenPlay 7205 Multimedia Projector Logo
1,861 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
