Question about Dell G6632 146 GB SCSI Ultra320 Hard Drive
Poweredge 2600 We have a Dell powedge 2600 with 4 36gig drives (hot swap), and 2 empty bays for additional drives witha Server 2000 operating system. If we purchase an additional larger drive, can it be plugged into an empty slot and will it automatically configure, or will it require system configuration beyond that of Dell Array Manager?
  • bilicke Nov 28, 2007
    It worked just like you said! Thanks for the help!!
  • 99 Answers
A larger drive should auto-configure just fine keep in mind that you may not get access to the full drive depending on how you have it all setup. In any case if there are any problems with the auto-configure you should be able to easily go into the RAID manager and tell it what you want to do with the drive.
Posted on Nov 14, 2007
Can I install Windows home sever 2003 on a dell poweredge 2600
I would say yes so long as your server meets theses requirements
Minimum system requirements The following minimum specs are needed:[24]
Additionally, the following are required for installation of the operating system only:
Apr 16, 2010 | Dell PowerEdge 2600 Server
Connect ide or sata drives to a dell poweredge 2600 for additional storage
Yes and No..
The standard machine only allows SCSI, (no IDE or SATA or SAS connectors...
However SCSI drives are not cheap.. so
To overcome the power issue (you will notice there are no 4 pin molex connectors, or sata power connectors). However there is a 4 pin molex socket on the SCSI backplane. You can use one of those molex adaptor cables (one connector to many) to get power, from the molex you can use a 4 pin to SATA power connector.
Next step is to decide the drive you want to use. I personally use SCSI, SATA, SAS and IDE in mine (overkill I know).
Cheapness says use IDE or SATA. You can get a pci IDE/SATA controller card on ebay dirt cheap (PCI cards are compatible with the large PCIX slots), they dont take the entire "socket" up but they work (be carefull here, there is one 5v pci socket on these machines, and 6 pcix sockets, the pcix sockets will accept 3.3v pci cards (look at the notches).
Next you have to mount them, with a bit of jiggery pokery you can feed the IDE/SATA cables past the SCSI backplane into the hot swap bay. (If you dont have any empty caddy's pick them up off ebay), just remember you cant just pull em out like you can with the SCSI's!) - or use one of the 5 1/2 media bays.
Plud the other ends into the appropriate controller card (as installed in the PCI bus).
Load up the OS, install drivers (if needed - these should come with the pci card(s), use the disk manager to initialise/first format the drives etc.
All done.
I have done this myself running a 2600, with 2X U320 72gb SCSI (on Raid) 1 x IDE CD/DVDRW in Media bay, DAT 27 SCSI (channel B) in the second media bay. 2x 146gb SAS on a DELL SAS pcix card (in 2 of the hot swap bays) and an old 160gb IDE HDD (Funilly enough theres a bit towards the back of the two fans on the SCSI backplane that if you press the 3 1/2 drive against seems to fit perfectly in this place and stay there! (I think thats fluke to be honest).
All done :)
Jan 04, 2010 | Dell PowerEdge 2600 Server
Drive Options with a Dell Poweredge 2600
I would definitively not recommend to remove the backplates, unless you want to ask for serious trouble with your system.
I would install a PCI SATA adapter card (one like these) and connect your SATA drives to it.
May 27, 2009 | Dell PowerEdge 2600 Server
I'm having some trouble with a dell poweredge 2650 I bought off eBay.
You are not too clear, however I'll take a guess ..
1) Booting from CD ... older CD drives fitted to PE26xx range do not recognize Windows 2003 bootable install CD's .. the TS-L462C (a laptop drive) should be compatible with the PE 2650 (I know it works in my 2600)
2) Installing the Operating System onto the PERC SCSI Array drives .. a total pain .. with older OS (Windows 2000) you can use the 4 x floppy disk set to install and hit (F6 ? as I recall) to tell it to 'load a 3rd party driver' ... get the PERC drivers from the Dell site.
Alternative = toss the useless Tape Drive and install a set of SATA drives in the same space (a 3 drive Hot Swap caddy eclosure will fit = Icy Box or StarTech) .. you will need a PCI RAID card (such as Si3124) since the M'Bd has nothing but a combined floppy/TapeDrive IDE interfafce.
3) Finally, be aware that this is a SERVER level box .. spare parts & Dell 'official' upgrades are going to cost you an arm & a leg = and don't even ask what the special 'ECC parity' Memory sticks cost :-)
Jan 22, 2009 | Dell PowerEdge 2650 (PE2650BB) Server
I need to add more hard drives to my poweredge 2600
You'll probably need to get caddies for the drives. You can get them from Dell by plugging in your service tag at
Jan 12, 2009 | Dell PowerEdge 2600 Server
Can i add 142GB of hard disk on Dell PE 2600 motherboard
You can always add more storage to a server, as long as you have enough internal connectors in the server. You can also purchase another scsi or sata backplane to add more ports if you're out of internal connectors.
You may also want to look into a SAN or NAS device to offload some of your not too frequently used data. Many SAN devices give incredible performance with pretty good scalability.
Sep 16, 2008 | Dell PowerEdge 2600 Server
New HD in PowerEdge 2600
Put the hard disk in, allow the OS to identify it, format the drive and you'll be all set.
Jul 19, 2008 | Dell PowerEdge 2600 Server
PowerEdge 2600 does not boot up ?
you need to set the boot device order. Usually F12.
or you can go to bios with F2 or F10.
your cd-rom is wrong you need the Instalation and Server Management CD. I think it's possible to download this cd at their site.
good luck
Dec 03, 2007 | Dell PowerEdge 2600 Server
CDROM and with a bootable CD is not been detected
Same solution as posted before if you need to boot from a DVD: take a Dell laptop CD/DVD combo drive, remove the screws and all and exchange the PowerVault CD drive unit with it. Same internal connector. Can't remember what model I stuck in, but I had to keep the front panel of the drive since it was slightly different, I probably could have glued it, but.... That's a server machine no one is ever going to see but me! :)
That also gave me a CD-Burner which is a decent addition in case you need to quickly burn a CD/make a backup/boot disk (like a "ultimate Windows CD" boot to fix anything that could go wrong).
Nov 29, 2007 | Dell PowerEdge 2600 Server
Dell G6632 146 GB SCSI Ultra320 Hard Drive Logo
145 people viewed this question
Alun Cox
