Question about Zenith HDSAT520 DirecTV DTV Receiver
Viewsonic HDCP LCD & DirectTV HD receiver
I just purchased a Viewsonic VX224w LCD with HDCP and am trying to view DirectTV via the DVI connection on the LCD. I am using an HDMI to DVI cable between the DirecTV receiver and the LCD monitor. However, regardless of the DirecTV receiver's display format (480i, 480p, 720p, 1080i), the LCD monitor displays "no signal" when I turn it on, and then a black screen. Any ideas of what I might need to do view output from the DirecTV HD receiver on my LCD monitor?
  • 2 more comments
  • pcslave Nov 13, 2007
    I don't understand. What are HD RCA's? And what do mean by Working cable?
    Sorry, but I still don't understand. There is an RCA video output jack on the DirecTV receiver (non-HD), but there is no RCA video-in jack on the LCD monitor. My goal, which I realize now that I was not clear on in my original post, is to view HD video from the DirecTV receiver on my LCD monitor. The DirecTV receiver has Component and HDMI outputs for HD Digital video (also s-video and rca for non HD video), and the LCD monitor has DVI-D input for digital signals and standard VGA input for analog signals.
    When you are referring to High Definition RCA cables, do you mean the RGB Component cables? If so, then the problem with that is that my LCD monitor does not have an RGB component video input.
    Thanks for you help...
    From what I see, Viewsonic's specs on the monitor *do* indicate HDCP support:
    http://viewsonic.com/products/lcddisplay...
    (VIDEO INPUT Analog/Digital RGB analog (75 ohms, 0.7 Vp-p)/DVI-D (with HDCP)
    I don't see a setting in the LCD's on-screen menu that references turning HDCP on/off. Is that what you meant by "proper setting in the monitor"?
    There is no on-screen menu adjustment for HDCP (or button, etc) on the LCD, but all is working now. I went thru a reset on the DirecTV HD receiver, and I can now see video at either 720p or 1080i. I should have done that first! DOH! Thanks for your efforts...
Will Direct tv recievers work with my new 23" widescreen ACER monitor? The monitor has VGA input,DVID withHDCP input and HDMI input
Posted on Mar 02, 2009
    Sergeant:
    Champion:
  • 306 Answers
Connect it with HD RCA's....then youll have both HD and Working cable.
Posted on Nov 13, 2007
  • 2 more comments
  • cory casper
    cory casper Nov 13, 2007
    High Definition RCA Cables.....will solve your problems, dont use the dvi cable.
  • cory casper
    it looks like you could view 720p unless the
    flag is set. If the content provider wishes the output to be
    encrypted, then only an HDCP enabled display device can view it.
    I didn't see HDCP in your monitor's specs, so the 720p could be
    disabled at any time. As soon as a source device emits an encrypted signal, you monitor cannot view it .
    So verify that Direct TV has enabled the High Definition. And propper setting in the monitor.
  • cory casper
    Yes, their is no Menu or other buttons on the front of the screen?
  • cory casper
    Yes, I wasnt sure if it had the reset on that model or I'd had you do it the first time....Clad we could solve the issue.
    Please rate this as fixed, and have a wonderful day.
Upgraded Sky+ to Sky +HD, but I now have a messages saying this display does not support HDCP?
Yes your tv is hdcp compliant.
This may not help but often when this message comes up it is the hdmi cable you are using. I do not know whether or not you are using an hdmi to dvi cable or an adaptor or and hdmi to hdmi connection. The cables available for purchase at beachaudio.com are not expensive but they usually work when you need to try another hdmi cable because of this particular message.
Mar 03, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Cant get hd to work
What is HDCP?
HDCP stands for High-Bandwidth Digital Content Protection, a copy protection scheme to eliminate the possibility of intercepting digital data midstream between the source to the display. The format designed by Intel and licensed by Digital Content Protection, LLC using an authentication and key exchange procedure before video and audio is presented. Products compatible with the HDCP scheme such as DVD players, satellite and cable HDTV set-top-boxes, as well as few entertainment PCs requires a secure connection to a compliant display, the process often described as the handshake. Due to the increase in manufacturers employing HDCP in their equipment, it is highly recommended that any HDTV you purchase is compatible. Although most video devices support high-definition video over component output, analog connections are scheduled to phase out in the future or possibly forced to limited resolutions output.
Why is it important to me?
Although manufacturers are still making most products with at least component HD output, new generation of products like HD-DVD and Blu-Ray devices will limit the analog output resolution (Analog defined as Component or RGBHV). The highest resolutions these devices can output (720p/1080i/1080p) will be available on via the digital (DVI or HDMI) connections that employ HDCP encryption. Any new HDTV purchase should have a digital HDCP compatible input.
It is important to note that HDCP is currently not a standard used in PC monitors, and almost none of these displays have Component inputs. Although PC monitors are HDTV capable, HDCP encryption limits this type of use. If you use an HTPC and want to ensure dual use of your new flat panel display, look for HDCP compatibility.
How does it work?
A simple answer is that an HDCP session will result in the exchange of keys between the source and display device. The source device will query the display to make sure that the equipment is HDCP compliant before video is shown. Non-HDCP devices such as PC's and older model DVI products will work with any DVI compliant display, but the HDCP compliant boxes will show an image only on HDCP compliant display.
Other products affected by HDCP are scalers, switchers, and splitters (distribution amps). While these devices do no authentication for key exchange, they must be able to transmit the presence of HDCP if the video is handled (processed) in any way. Due to the two different formats of digital connections, occasional inability for proper communications may result in loss of interoperability. The newer format, HDMI was designed to be backwards compatible with DVI and in most instances, the two signal types are easily adaptable, but older devices may not always work well with in-line devices like scalers or switchers. These problems can sometimes be fixed in "firmware' although that is not always the case. Incompatibility is often displays on-screen as a snowy image or an error message.
Hope this explains it for you.
Jan 08, 2011 | Televison & Video
When trying to connect a phillips soundbar/dvd player into my tv using the HDMI cables/ports - it said it was not HDCP compatible. We tried teh different HDMI ports
If this equipment does cause harmful interference to radio or video reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
  • Reorient or relocate the receiving antenna.
  • Increase the separation between the W4207 HD Monitor and receiver.
  • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
  • Consult the Westinghouse Service Center or an experienced technician for assistance.
DVI CONNECTION: Connect a Digital DVI cable from your computer to the W4207 HD Monitor DVI port. Using a 3.5mm mini cable to RCA Red/White (Left/Right) audio converter cable, connect the 3.5mm cable plug into the computer
Dec 13, 2010 | Westinghouse W4207 42 in. HD-Ready LCD TV
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
DVI input does not work. Senses input but shows no signal.
Could be a hdcp issue. If the bluray player is High-bandwidth Digital Content Protection but the tv isnt then youll get no picture, can you connect via scart.
see here for info
http://en.wikipedia.org/wiki/HDCP
Feb 05, 2008 | Dell W3000 30 in. HD-Ready LCD Television
Problem with picture
Most likely it's the LCD panel assembly failure. Either the inverter board or scaler board.
Jan 18, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Hp hd dvd player for desktop wont play hd dvds
I had this problem. Turned out that I was using a DVI cable to connect my monitor to the video card, but my monitor was not HDCP compliant. Most HD-DVD's require the monitor to be HDCP compliant for digital output (i.e. over DVI or HDMI connections). Alternately, you can connect to your monitor via its analog (VGA) input instead, but you won't get HD output. I was able to do this using a VGA cable along with the VGA-DVI adapter for the video card output.
Cyberlink has a tool you can run to see if your system is capable of HD-DVD output. http://www.cyberlink.com/multi/support/bdhd_support/diagnosis.jsp
When I ran it, it gave me a red flag telling me my monitor was not HDCP compliant
Aug 05, 2007 | Pioneer VSX-D511 Receiver
LST-3510A
Hello, I've been reading up on the LG LST, I got the same device. Two options that you may want to try (and there may be a third). 1st) Make sure nothing has happened to your DVI cable, make sure it is tight on both ends. Undo it and blow on the connectors and resecure it if need be. HDCP involves communication between the HDCP chip on your LST and the HDCP chip in you display. If you cable is loose, dog chewed or too long then it may be interfering with your HDCP handshake. 2nd) You should be able to go to RGB display option and dispay in HD over the same DVI cable. This was discussed much in the forums I have been reading about. I hope one of the above options helps you. In fact I hope the vacume or kids knocked the cable slightly loose and you are back in business after tightening it. The 3rd option would be to do a google search for LST-3510a and HDCP, you will find all kinds of solutions, work arounds and firmware update discussions. Good luck! Scott
Sep 26, 2006 | LG LST-3510A DVD Player/Receiver
Open Questions:
Zenith HDSAT520 DirecTV DTV Receiver Logo
481 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
