Question about Toshiba Satellite A100-S8111TD Notebook
Fracures on the screen,plastic not broken
My daughter used my laptop now i have fractures on the screen that seem to move around.
  • 85 Answers
Do you have a picture available. If not can you describe the problem more.
Posted on Nov 12, 2007
How do I fix or replace a broken Hinge on Dell 500 Laptop
The hinge rarely breaks, the fixings come loose and split the plastic case.
Disassemble the laptop to find out where your problem is,
DELL Vostro 500 PP29L SSD
If the plastic has broken off, I use epoxy resin to repair around the hinge or look on fleabay for a replacement hinge.
Dell Latitude D500 Laptop 14 1 034 Screen Hinges eBay
Feb 06, 2017 | Dell Computers & Internet
Laptop screen replacement
If you've removed the screws that is on the plastic that is around the outter edges of the screen then use a little force with your fingers to pry the plastic bezel apart from around the screen. Normally this is snuggly snapped into place around the screen. Surely some knucklehead did not apply glue to it.
Mar 10, 2012 | Computers & Internet
Cant remove screen seems glued on hp pavillion dv5 1007
ummm, i'd doubt that it is glued unless you had the screen repair previously by a shoddy repair shop. First of all normally the screens are held in place by screws that are hidden by little rubber bumper covers or some type of covering on the plastic that is around the screen. Use a safety pin or small flat head screwdriver to remove the covers and expose the screws. Then use a phillips head screw driver to remove the screws. Once all the screws are removed use your fingers to slide along the inside of the plastic around the screen and pry it loose from the screen.
Laptop screen has been invaded by green and red/purple germlins
Sorry to tell you but you are describing exactly what an LCD looks like when it has been fractured. Does it work with an external monitor? If so you will need to have it repaired. Call the Fujitsu support number (800)-fuj-itsu and they can tell you where a repair center is in your area. The call is free. Have your serial number handy.
Mar 09, 2009 | Fujitsu AMILO PC Laptops
Charging System does not work and Lines on LCD
I have a dell 9300 that had vertical lines.
I wrote to Dell and said my wife, my sister, my daughter and myself had trouble with the laptop screens. They did not reply but sent me a box with return mailing instructions. Without a word either way, my laptop was fixed. There is no question in my mind there are shorting problems under the case. On three of my dell laptops I need to use a cord to plug in. THE BATTERIES have some sort of connection problem. If I touch the bottom part of the case(while entering data, it oftentimes moves the mouse or the mouse starts dancing. I have to work without the battery. I read where some fellow opened the case gently and inserted a hard piece of thin clear plastic to separate the case somewhat from the guts, so to speak. That may be some help. All of my laptops are kept open now while I can. It seems the back where the lid goes down is fragile. On two of my laptops, the usb ports moves about like a broken arm.The internal architecture is great on a dell. They might use tin cans to make the outside. I wish they would use a solid plastic.
If you can try a docking station that might help. I do not think you can do anything else other than see if there is an open line from where your batter plugs in up to the motherboard.
Jan 25, 2009 | Dell Latitude D800 Notebook
Advent laptop overheating
Check the jack on the machine to see if it's loose or broken. Use a small screwdriver, and see if you can move it in any direction. If it is loose or broken, get it fixed imediately. A loose or broken jack can create an electrical arch which can do severe damage to the machine.
Jul 22, 2008 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
