Sewing Machines Logo
C
Cheryl decoursey Posted on Feb 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motor runs machine jams, wheel hard to turn
Machine sewed today but pressed pedal, needle jammed in material and refused to continue. Needle would not come up and wheel was extremely difficult to turn.
Anonymous232
Level 3:
Genius:
  • Master 1,552 Answers
  • Posted on Feb 24, 2015
Anonymous232
Master
Level 3:
Genius:
Answers
1552
Questions
Helped
270169
Points
2945
Unless you are a qualified service technician, take it to a technician for repair. Trying something yourself may cause more harm.
Juki dnu-1541 S hard to turn
indicates needle thread tension not tight enough
the jamming may be from thread and fluff wound tight around the bobbin shaft an locking it up
remove any threads and other material from the bobbin shaft and bushes
take it in for a service
2answers
Why doesn't it sew?
Check to see if the bobbin case is in correctly. Jamming occurs when something isn't in machine properly. Try taking out the needle & manually turning the hand wheel slowly. It could be just a bent needle too.
1helpful
Sewing machine jammed with needle down and material can not be removed. Help I can break the needle, I really just want the fabric out.
Usually, the needle & fabric will release if you are able to remove the bobbincase and the needleplate. You should probably try to do this to remove the broken needle tip, although usually it will drop out of the bobbin area and land somewhere in the bottom of the machine.
1helpful
My Janome magnolia is 3 years old. Last week I was sewing and everything jammed, needle went to side and broke. It was trying to run but couldn't. I took bobbin out and cleaned it, oiled everything, where...
Try the process of elimination. Take out the needle, take off the needle plate, take out the bobbin case. Run the machine. Does if run full speed? You might have to let the machine run for about 5 minutes. If it runs slow or you hear it slow down, you might have a bad connecting link between the needle bar and the main shaft counter weight. They seize up sometimes. (Shop Repair).
Machine jammed wheel will not turn needle will not move
Thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands
Janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Engine occasionally jams, still able to operate manually
It's been a while since this machines been oiled. try oiling both motor hole and needle operation.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
