Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis dryer
The dryer is making a high pitch noise. I think it is the belt or belt tensioner. But how do you get access to it.
  • Anonymous Mar 31, 2014
    Cannot figure the belt installation I belie:-) be there is a pin or something to aid in belt tension
Why is Maytag Atlantis is not drying like it use to?
Posted on Dec 12, 2007
Diagram on how to replace belt for Maytag MEDB200VQ0
It sounds like an issue with the drum belt tensioner or the tensioner wheel.
Oct 02, 2014 | Dryers
I just cleaned and greased the rollers for the drum when it was making a load high pitched noise. Now it makes a different noise and the drum won't even turn. What should I be looking at?
I would make sure the belt is on correctly. I'm assuming (darn me for assuming) you removed the tub? if so, did you see how the belt goes on the pulley? remember the fiber faces up and the pulley puts tension on the belt
Feb 03, 2011 | Maytag Dryers
My dryer is making a high pitch squeaking noise during certain times of the drying cycle. Is it one of the wheels that turn the drum? Don
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 18, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
Dryer making a high pitch squeeling sound when
The idler bearing that keeps tension on the belt is going out due to heat leaching the grease out of it. Have it replaced.
Apr 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag Atlantis Gas Dryer makes a loud noise when it is running. It works fine except for the noise. I have had the dryer about 5 yrs and this noise just started several days ago.
is it a high pitch noise. Like a noise that sounds similar to a old freddy cruger movie when the little girl on the tricycle passing by. If it sounds like that, then maybe you idler pully needs to be oiled..the idler pully is what keeps tension on the belt and lets the belt rotate smoothly. just like a pully. That maybe needs to be oiled..try doing that and see that works.
Jul 26, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer makes a whining noise when drying
The belt is not the problem but more likely the drum rollers or drum bearing will need to be replaced.
Jan 29, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
GRINDING NOISE
Definitely need more info. However, probable causes:
1. Broken/worn drive belt - replace belt.
2. Loose piece of debris between the inner drum and outer shell. - remove any alien/non-standard part/s found.
Both require access to the back/top of the unit. Standard tools may be required.
CAUTION: Ensure unit is unplugged before opening any cover. Most appliances are mass produced. As such be aware, units tend to have sharp edges inside.
Mar 04, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
SQUEAKY DRYER
HOW DO YOU ACCESS THE REAR DRUM TO APPLY THE OIL?
Feb 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
750 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
