Question about RCA P52926 52" Rear Projection Television
Snowy picture everything works except the screen or picture is snowy
    Brigadier General:
  • 6,966 Answers
A snowy video indicates that your input signal is relatively weak. On the other hand, a noisy picture is when there are too much interference is super imposing on the video.
Snowy picture comes about when the signal coming in the RF INput (Ant/Cable) at the back of the unit is below a certain level. If this is the case, then it is not a problem with your TV but rather your aerial (antenna) or the cable from your provider. A way to verify that it is the ant/cable that is the cause and not a defective TV/tuner is to hook up an old VCR set to Ch. 3 or 4 to the RF IN of your TV using a short 75 ohms coaxial cable terminated at both ends with FP-5 connector. Play a known clear good tape and set your TV to Ch. 3 or 4 as the case maybe. If the picture is relatively clearer, better, then you have just confirmed that it is indeed your aerial or your cable (provider) that needs looking into. If on the other hand, the VCR signal is also snowy then chances are that you have a problem with the input stage of your TV including possibly your tuner.
For your aerial problem, antenna orientation or replacing with a higher gain antenna might help solve the snowy signal. For your cable problem, you have to call-in for service from your cable provider. If it is a TV problem, your best course would be to seek the services of a qualified TV technician since this involve electronic circuitry analysis, diagnosis and possible component replacements.
Additionally, you may try looking for any loose connection, loose grounding, broken wire or anything out of the ordinary in your connections.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 13, 2007
  • Louie  Role
    Louie Role Nov 13, 2007
    Hi again,
    If your location is relatively far from the TV signal source, you may want to consider using "signal boosters" the purpose of which is to amplify the incoming TV signals before it even reaches your TV. A fine example is HDP-269 Preamp by Winegard.
    Cheers.
LG flatron plasma rz42px10 snow screen with sound
Check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 11, 2017 | Televison & Video
Snowy picture
The remote doesn't effect the channels, I would say you have poor signal or interference from another device nearby.
Sep 12, 2008 | Orion1934 19" TV
What would cause a GE 60GW948 have a very snowy, and now No picture screen
when you say gone out---no light on screen or brightness or what? The snowy picture can be got around in most cases.
Jun 14, 2012 | GE 31GT660 TV
No picture in a picture
The picture for picture-in-a-picture must come from somewhere. Try a DVD for the picture in picture. It may be the second tuner for the picture in picture that has failed.
Mar 30, 2010 | Hitachi 50UX26B/27K 50" Rear Projection...
The screen has went snowy and wont respond to the remote
Snowy screen, unresponsive to remote control... Sounds like an interference from something. An example... A hairdryer can mess up a CRT really bad. Anything that is likely to create small EMPs will surely mess up your TV and even interfere with the infra-red. Not marking this as a solution, check everything and test the TV. Here's the test: Turn everything off, except for the TV. If it's still doing it then the remote infra-red is just a coincidental failure with the snowy screen. Sorry I can't help you further.
Oct 16, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Snowy LCD on Kodak z712
you're silly!!
the "veiwer"window should have a means to "focus"near it!!
(the focus is ONLY for the "veiwer")
good luck!
Dec 17, 2008 | Kodak EasyShare Z712 Digital Camera
Picture loses all normal color & changes to snowy blues & greens
Not sure what causes it but it can be fixxed by your local repair guy, I just had mine fixxed for under a hundred bucks, he takes the back off and with a tiny screw driver adjust a few screws to near brand new perfect picture.. and it has been good ever since
Dec 01, 2008 | LG RU-52SZ30 52" Rear Projection...
Computer monitor problem
power supply is most likely going could be capacitors on the vga /inverter board also needs to be checkd out at a service location
May 01, 2008 | Gateway FPD2275W LCD Monitor
Snowy Picture, Toshiba 42HP84 plasma tv
Similar problem with my Toshiba. I was told it was the power supply and that it would cost about $900 to replace parts and labor
Nov 21, 2007 | Toshiba 42HP84 42 in. Plasma HDTV
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
RCA P52926 52" Rear Projection Television Logo
188 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
