Related Tags:
This problem should be removed because:
Problem with Motorola RAZR V3
blank screen
my razr screen is blank. on the outside & inside.
i can turn it on, make calls, recieve calls, everything.
but i cannot see. i read that i should hold * and #,
but this does nothing. i also read that if that doesn't
work then it must be the flex cables.
if that is the problem, can this be fixed? and how?
Solutions (29)
Best Solution
Seriously, bang the phone sideways on a desk, it works! Do it on each side 2 or 3 times, then back again. Don't slam it down, but bang it a couple times I'm not kidding at all
wow. I was reading all this banging stuff thinking it was crazy. After banging the phone on the floor a few times, then taking the battery out and putting in back in - - - the darned screen came back on! And I used to wonder why Grandpa slammed the old TV with a shoe every time it went on the fritz. That worked, too. Thanks!
I thought everyone was crazy about banging their phone. My phone worked but screen was pitch black. (Bought phone in May 2007 so I don't think it should die yet and I've dropped it a couple of times since then). Today was the 1st day the phone turned itself off (it was fully charged) and went black.
I put phone in charger, turned it off and on, and, while on, I banged it a couple of times on the desk (a soft bang). Now, the screen is working! This is nuts but phone is working now so I don't have to buy a new one.
I drop it about 2 ft on a hard surface. (a controlled drop) It works again initially. I don't want to shatter the screen. The display comes back and I can see to touch tone the #s, text, and make calls. It really seems to be a problem with the ribbon connection between the phone and the screen lid, I've been told. But for me, the phone seems to work a higher % of the time when it is in between a 80% charge and a 25% charge. Funny it is so intermittent. I'm trying to coast to the end of this contract so I can get a new one! Thanks for your suggestions about rapping it. That really does work! Hasn't Motorola done anything about this??? Bill
I dropped the phone really hard on the ground and screen was blank for days. The phone still worked just without the screen. I read all the post and decided to try the tapping on the side. I did it a few times on each side. The screen went white for a few seconds, then came on. This just saved me a $100 awesome.
THIS its JUst amazing hahahaha it worked...my girl friend phone a v3 pink was ruined well the screen cuz last night fell into the ground so hard and there was water on it...so i was looking online for help i found this and she didnt want to do it ...but i made her hhaha and it amazingly worked hahahah ...and its perfect now ....bang it works
I thought banging it a few times was a ridiculous idea... But it totally worked! Turn your RAZR off, tap it 3-4 times on a hard surface (each side) and it should work when you turn it back on! Hilarious!
WOW banged the phone and it worked. Who would have known!
Yes!
I had only the top third of my razr's screen showing. The bottom section was illuminated, but white with light gray vertical streaks. After reading posted solutions, I tapped the closed razr (which was turned on) hard two times on both sides. I then turned the phone o off, then on, and now the entire screen shows! It really worked! Hopefully it's a lasting solution. Thanks for good advice.
u are all rong u have to throw ure phone 10 ft above head for real then is works
Thanks for the suggestion! I did tried turning the phone sideways and banging it. And the screen came back on! Thank you!
There might be dust or dirt in the phone which has clogged up the contacts between the screen and the keyboard. Dropping the phone a short distance does seem to help, and it must have knocked the dust loose from the contacts. I tried this and the white screen does not come up as often, but I probably will have to take the phone apart and get the dust out of it.
my friend had the same problem she removed the battery put it back in and it worked fine
The 2 solutions given so far seem unlikely, but hitting my Razr worked for me. I turned it off and on, took the batteries out again and again, and even made phone calls all with the black screen. I finally was frustrated enough to literally punch the face screen while it was closed. Not enough to break it, but enough to show I meant business. Anyway, it works fine now.
turn the phone sideways and bang it on something hard like a desk.
Just Click On The Problem or
Phone Model For Solution,
Motorola RAZR V3
Unlock Software Hardware
Motorola SLVR L7
Motorola RAZR V3i
Sony Ericsson K800i
Sony Ericsson W200i
Hope These Works
Try the link . . . http://www.Motorola.com/Razav3
For find best solution.
14
Hi Friends,
Having problem with Motorola RAZR V3? Main problem of Motorola RAZR V3 is hardware problem. Such as won't charge, black screen etc. For solution of these hardware problem just click here.
For any other problem of Motorola RAZR V3 like software problem or other just click here.
Didn't work for me either. Calling Motorola wasn't much help either. They said I had to send it in and it would probably cost about $75. Because of the rebate I got, that's more than I paid for the phone! Any other ideas?
U guys r great! I tried banging it 3 times on both sides (not the screen side) but I guess it wasn't hard enough so I did it again, turned the phone off and when it came on it was working again!!! This really works!!! Thank You SOOOOO Much!!!!!!
I thought you guys were nuts about banging it.
I tapped it ******* the hand a few times. Nothing. Did it again, both sides, IT WORKED.
A small amount of water caused the problem.
It's fine now.
thx guys for all the help my razer worls good as new part from all the bumps and a smashed frunt screen
My phone works fine when its open. when its closed, however, i get a blank outside screen and inside. the phone works alright, but i just cant see anything! after reading posted solutions, i banged each side 3 times and it worked!!! thank you!!!
tapped it a few times works great for now thanks
My screen only goes black while running a app .. If I switch it of and on it comes back on ....most of the times ... I'm going to try the banging thing couz that dam phone makes me wanna throw it out of a moving car ...
Didn't work for me ><. Guess it only works for razrs?
Okay... yeah no. I've tried all of the above. No worky. Any more solutions?
yes it does work i just did it thanks.
Suggested Solution (1)
blank screen inside, ok on the outside screen..
blank screen inside, ok on the outside screen.. my fone receives and sends messages, calls, but the screen is all white... ive tried to...
blank screen
my razr screen is blank. on the outside & inside.i can turn it on, make calls, recieve calls, everything.but i cannot see. i read that i...
blank screen
cleaning flex cable on Razr
I read the post for fixing a blank screen. I removed the 2 screws using a Torx 6 and now I am unsure what piece should come loose? I...
blank screen
my phone is a samsung slide from koodo. when I turn it on the screen goes white blank, it lets me call out and recive texts and what not. Is...
Add Your Solution
envelope pen
Looks like an icon with an envelope and a downward pointing pen in the lower left corner. How do I get rid of it and...
motorola vga4xz00m
do you need to add time to the phone to transfer pictures to a home computer.and also cant get it to charge from usb or...
call when dead and no display
switched on there is no display
I lost the phone itself with the sims card in it
And it is in my house i think
Related Topics
Fix-O-Meter
2,078
2,078 people viewed this problem
- 6 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Motorola Cellular Phone Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
