Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Glass arent coming clean
I have been having issue with our dish washer, the glass are coming out with particles in them it only seems to be the glasses right now. Is there some thing i need to do to fix this
  • 126 Answers
Make sure you are loading bottom rack right remember water has to get up through your bottom rack to rinse out your glasses.
Posted on Dec 13, 2007
How to remove large food particle trap in a electrolux dishwasher model # EWDW6505GBO
Good Morning Friend,
I understand you want to know how to remove large food particles that are trapped in your Electrolux dishwasher, model# EWDW6505GB0. First, I would suggest that you scrape away large pieces of food before putting any dish in your dishwasher.
Your dishwasher is equipped with a state of the art wash system. Periodically, the Glass Trap Filter and Large Food Particle Trap may need to be cleaned to maximize wash performance. The Glass Trap Filter is located in the center of the Large Food Particle Trap. The Glass Trap Filter is designed to collect pieces of broken glass, straws, bones and pits. To remove items in the Glass Trap Filter, grasp the handle, lift out, empty and replace. Hope this is helpful.
-Best Regards-
Jun 25, 2014 | Electrolux EWDW6505GS Fully Integrated...
Glass and Glass cups or Plates come out dull, like covered with thin limestone powder .
I suffer the same issue it was only fixed by upgrading the washing tablets used
Oct 19, 2012 | AEG Favorit 50500 Built-in Dishwasher
Hello I have an Ariston advantage AF300 dish washer. And it has stopped working properly. The problem seems to be that no water is being sprayed around inside. The machine works its way through the...
You either have a food or glass particle lodged in the wash motor impeller not letting it turn or more likely the wash motor capacitor needs replacement.
I suggest getting a repairer as the Aristons are tricky to repair.
Sep 03, 2011 | Ariston Technologies Dishwashers
It is an older model maching and it seems to be clogged and not cleaning the do you unclog it
It would be helpful to know exactly what machine you have, but the bottom line is, you need to access the screen at the bottom of the machine, where the water exits into the pump. Many units have a macerator blade in front of the screen that chops up large particles of food so that they will pass through the screen. The blade is attached to the same shaft as the pump, which both supplies the high pressure water to wash dishes and pumps out the dirty water at the end of the cycle, and if there are small hard particles, such as bits of bone, plastic or broken glass in there, they can jam the blade so that the pump does not pump properly. You will need to remove the dish racks whatever covers, etc., are on the bottom inside the machine to get at the screen and/or macerator.
Mar 18, 2011 | Microwave Ovens
Dirty cups and baby bottles after dishwasher has been run
Hi and welcome to FixYa I am Kelly. One of the biggest causes of the symptom you describe is that there is a partial blockage of the drain. The blockage areas are most often in the "Air Gap" A device that looks like an inverted 5 oz Dixie cup on the back of the sink with no cone shape. Food particles collect in the very top of that and slow down the drain process. Because of that the dishwasher doesn't completely drain between cycles. So what you get is recycled previous cycle water in the rinse.
Other places where blockages occur are at the garbage disposal side inlet hole. And the last place is under the wash arm tower / mini riser in the pump impeller outlet area. To clean under the lower wash arm riser it requires diassembly and a good memory of how everything came apart / goes back together when your done cleaning.
Apr 18, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Small food particles getting stuck
Check your drain filter and clean them. refer user manual for location
Apr 06, 2010 | GE Nautilus 24" Built-in Dishwasher
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dwc7400aaw maytag -glass are cloudy,groundup food particles drying to dishes & glasses,when filling makes loud high pitched sound-generally not cleaning well.
The problem is hard water. has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Apr 06, 2009 | Maytag MDB9600A Jetclean II Built-in...
Cleaning Oven Door Glass inside face
First take the two inside screws out, (found at the top of the door) they will pop out when you have both sides off so make sure to take them all the way out so you dont lose a washer or one of the screws. The handle is actually secured by these 2 screws and will come off of the door when you remove them.. your metal door can bend slightly in this process, so be careful. as soon as the handle and screws are off you can clean inside of the 2 pieces of glass, also a good time to clean off the opposite side of the door behind the handle. only take the 2 screws off no need to remove the full door. I used a magic eraser to remove the grease and then I cleaned the glass with glass cleaner. I used a small vice to secure the door when putting the handle back on, but you could have someone to hold the piece togeather for you too. (I have a frigidaire stainless steel model)
Nov 09, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
78 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
