The cable for the release lever might be stretched or broken. You have to get the tiller cover off to access it.
Thanks so much. I took the tiller stem apart and there was nothing attached to the locking lever. I am assuming there is a broken cable somewhere down there. just can't find a diagram on how it is supposed to be hooked up or if broken how to replace it. any suggestions will be greatly appreciated. the tiller moves up and down freely. the shock inside working fine just will not stop in one position.
You can go to the manufacturers web site to get maintenance manuals that are more informative than the owners manual.
SOURCE: tilt steering stuck in down position.wont tilt forward.
I am sure you have tried this but put it all the way down and let it lock. Then try and pull it back up. The problem will be if it stays stuck. I would wiggle the wheel at the same time. May need a third hand to help.
Testimonial: "thanx. will try it."
