If you are facing DNS probe error, then you must check this solution.
The error can be caused due to DNS server not reached, IP address conflicts, or because the network cannot communicate with IP address.
So the solution you should follow is:
1) Change the DNS server address into Google DNS server which is 8.8.8.8 and 8.8.4.4
Also, try other methods from here:
Best Methods to Fix DNS PROBE FINISHED NO INTERNET Error
You can fix DNS_PROBE_FINISHED_NO_INTERNET error in Google Chrome By Applying This Method:
Open Command Prompt (Run as administrator) in your PC.
Type the following code and hit enter...
netsh winsock reset
Now simply restart your PC and error must be resolved now....
Source: DNS PROBE FINISHED NO INTERNET
No internet, issue with connectivity. Follow steps at this link to resolve. BEST FIX DNS PROBE FINISHED NO INTERNET
The Wii is unable to connect to the Internet
Likely cause: The wireless router is incorrectly connected, or the Wii console will need a DNS manually entered.
How to fix: Check the way your router is connected; manually assign a DNS to the Wii.
