Question about Kenmore 15516 Mechanical Sewing Machine
Thread caught up around bobbin!
Often, after I have been using my Kenmore for a few days off and on (or just often during a given week) the machine works fine but eventually the thread (from the top) gets caught up in the tools around the bobbin until it becomes so tight that it completely and quickly halts all sewing. I've tried adjusting the tension, but it doesn't seem to be working? I feel a bit silly not being able to fix this, please help?
  • 1 more comment
  • NLT2007 Dec 31, 2007
    I have the same problem. Have you fixed yours yet Terumi?
  • Michie24 Mar 02, 2008
    Mine does the same thing!!!
  • RenRod Sep 14, 2008
    This is driving me crazy! A visit to Kenmore's website didn't help - I couldn't find any troubleshooting. Everything is threaded properly and I even disassembled the related parts to clean them, yet the needle thread continues to get caught in the bobbin area making a HUGE tangled mess. HELP!
    Problem Solver:
  • 4 Answers
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Posted on Sep 15, 2008
Kenmore 1774
My sewing expert (spouse) says you may have thread caught in the bobbin area. Remove all the thread from the top, they look inside, you may find the problem.
Be blessed.
Feb 01, 2014 | Kenmore Sewing Machines
Readjust the needle timing and check the thread tensions top and bottom.
Jun 09, 2013 | Kenmore Sewing Machines
Thread caught in bobbin housing of a janome 11574
it would be a good idea to have the machine checked to see if
the bobbin housing may need some adjustments or see if it's a
timing problem
Dec 20, 2012 | Janome Sewing Machines
Sewing issues
try changing the needle
rethread the machine top--also make sure the presser foot is raised all the way up before you rethread the top
& bobbin--make sure it's turned the correct way
make sure the bobbin is not warped or damaged
keep a eye on the thread take up lever, because sometimes the
top thread comes off of it
May 31, 2012 | Kenmore Sewing Machines
Top thread randomly breaks during sewing. very frustrating. Can not locate my manual.
make sure the thread is not caught around the thread spool
check the top tension it could be to high,,try 3 or 4
check top thread tension area to see if there's any loose threads or lint
check the needle to make sure it's not bent or blunt or have a burr on it- make sure it's the correct needle for the fabric
check needle plate for burrs
check bobbin for burrs
clean under needle plate for loose threads or lint--also in bobbin area
Aug 03, 2011 | Kenmore Sewing Machines
Top thread gets caught on crescent piece holding in bobbin case
If you have the manual take a better look at how to put the bobbin in the case,
sounds like you are putting it in wrong,
make sure you put the bobbin in with the thread com-ming off the bobbin in the right direction (left or right) if not put in the right way you will get what you are saying
ALSO: bring up the bobbin thread your self by turning the hand wheal and bring the thread a few inches to the back of the needle and hold when starting to sew the first 2-5 stitches.
when you do not hold the thread the machine will pull the thread in the bobbin area and cause problems.
you will get use to holding and it will get easier.
hope this helps
Sep 03, 2009 | Kenmore 15208 Mechanical Sewing Machine
Thread gets caught on the bobbin holder and won't
Hello there:
have you tried to adjust your stich pattern and slowed down your feed rate also doublecheck the bobin to ensure that it is installed fully in the casing and is not warped at all ok?
regards mike
Aug 18, 2009 | Kenmore Sewing Machines
Thread is bunching up around the bobbin casing
On the bobbin case is a small screw if it is to loose the thread won't feed like it should make sure that screw is tight but not so tight you can't get the thread through it. Also check to make sure you have threaded the top right. hope that helps
Oct 14, 2008 | Kenmore 15208 Mechanical Sewing Machine
Thread knotting around bobbin case
hello, I had the exact same problem and could not find the solution until i took my machine to my sewing sensei and i solved my tedious problem. It was actually not a tension problem at all but a threading problem. Make sure you have threaded your bobbin correctly and that when you pull on the bobbin thread that the bobbin turns the right way. (mine must spin anti clockwise to work)  Make sure that when you pull up the bobbin thread using the needle that it is not over the feed dogs connective bar but under it. A big problem when the thread gets caught around the bobbin case wheel is that the thread is looped around the feed dogs once and that causes the thread to get caught around the bobbin wheel. In conclusion, thread the bobbin correctly and read over your instruction book before spending the money to get it fixe in s shop.
Feb 26, 2008 | Brother LS-1217 Mechanical Sewing Machine
Kenmore 15516 Mechanical Sewing Machine Logo
389 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
