Question about Philips 9P5534C 55" Rear Projection Television
No picture or sound
When powering up the tv there is no relay click but the LED indicator on the front lights up. I also get no picture or sound. The pc boards are covered in dust. I think it may be a bad relay or fuse but I checked all the fuses and they are fine.
  • 1 more comment
  • AgentIndie Dec 28, 2007
    I am having the exact same issue on this model television
  • free2fly629 Feb 13, 2008
    I have the same problem. I am unsure in what to do!!!! We have just received this from a friend and not sure where to have it fixed. Any advice would be greatly appreciated!!!!
  • boss08
    boss08 Apr 26, 2008
    i have the same problem but where do i get this fixed and how much will it cost someone please tell me how to get this problem fixed
  • Philips Master
  • 3,459 Answers
Easy fix - check They have repair kits for this common problem.
Posted on Jun 29, 2008
Lcd tv troubleshooting
Check for power supply trouble. The green LED on the front panel should light if power is getting to your TV. The "no signal" indication may mean no antenna or cable input is detected
Aug 21, 2013 | Televison & Video
I have a Toshiba 51h84.I push the power button and I get a solid red power light. There is a click from inside, kind of like a relay clicking on. No picture, no sound. If I leave it on I get an occasional...
Tv have "LAMP" indication LED light blinking?The tv projection lamp is dead,require changing.Hearing alot of clickings sound too?Mean the board,call the Ballast board is dead.Require change the Ballast too.The Ballast board,the board that help to ignite the projection lamp.
Aug 06, 2010 | Toshiba 51H84 51" Rear Projection...
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
Power Issue
Now,u plug in the tv u get a solid red standby power red LED light in the front of the LCD panel right?When u push the power button on the remote u hear a clicking sound?Only one clicking sound,not the power supply board problems.It the Tuner board problems.But u can make sure it the power board problems or not.By taking the tv aparts check the power board,that board where the a/c power cord goes into it.Look all around the power supply board check for these leakage capacitors,they alway bulges up it top or puff up it top.No bad leakage capacitors,then it not the power supply board problems.
May 14, 2010 | Haier HLH406BB 40 in. LCD HDTV
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Blinking standby light on the front of tv...wont turn on no sound
They are dropping like flies -
Just posted this for the same set:
The sound; is it a click or a sharp snapping sound?
The first can be a relay turning on, the second is most likely related to a high voltage discharging.
If it is a relay, then the set could be trying to protect itself from an overload or the power supply has failed; the blinking ON LED is pointing toward that.
If it is a high voltage discharge (you may be able to see it through the vents in the rear housing) then it is possible that an accumulation of dust and household airborne contaminents has created a path that can be removed with some targeted cleaning.
Dec 04, 2008 | Sony KV-32S45 32" TV
Philips 43PP8545
You have no high voltage, like many in this forum, this model of Philips has some of the same problems. Look around here you may find the answer to your set. If not check Vertical IC, TDA8177, audio ic on signal board up front on left. check Power supply first for blown fuse, 1000, 2004, 1300, 1900 etc. No sound or pic means something is open. Does set has L E D lights on front of set?
Sep 02, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 9P5534C 55" Rear Projection Television Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
