Question about Young Living Home Diffuser - U.S.A./110v
How can I run my young living diffuser without the light on? I know that if you hit the button once the diffuser comes on. Twice and it will diffuse for a min or so, turn off (light still on) and then run again. I know there is a way to ru it without the light on but can't remember. Argh!
  • Insi Baba
    Insi Baba Jul 13, 2015
    You hold down the power button until it turns off
    or push it twice
    New Friend:
I had the same Qustion and found yours so I experimented and after you turn it on push the button and keep it held in until the light turns off!! Mine has the light off now!!!
Posted on Mar 11, 2015
Tell me please what kind Oil Reed Diffusers is very good?
https://www.bestadvisor.com/reed-diffusers
Pleasant scents evoke pleasant emotions. If you want to fill your place with pleasant fragrances, you definitely need to try a reed diffuser, an appliance used to perfume any living space with light scents of oils, creating a calming environment. Our review will help you choose a fragrant companion for your home.
Mar 27, 2017 | Air Tools & Compressors
Tip
DIY Pop-up Flash Diffuser
Wanting to lessen the power of your flash with under exposing your picture/subject?
Want to add natural light bounce to your subject and lessen shadows?
Wanting to have a pop-up flash diffuser without spending a dime?How about removing shadow cast when doing some macro shots?
If your answer to these questions are YES, then time to read this DIY guide. This should be easy to follow and the material(s) needed should be available in your home.
First, let's briefly discuss what a diffuser is. A diffuser lessens the strong/ harsh light coming from your camera's built-in pop-up flash, creating a softer and distributes the light evenly on your picture.
There are lots of pop up diffusers out there and are relatively cheap. However here's one that I've tried and tested and worked fine for me. Take the cap of your empty roll-on(deo) place it with your hand, right at the front of the pop-up flash(in it's popped out position). Then take a picture using flash. Try it with and w/o the cap to see the difference. Not impressed? Try it first and explore new ways of getting better pictures.
on Mar 23, 2011 | Cameras
Young living diffuser fan not working
That unit takes a 24 volt power supply. That is probably higher than what you have connected to it. http://www.youngliving.com/oil-diffusers/Home-Diffuser-US
Jan 22, 2014 | Young Living Essential Oil Diffuser -...
Aria diffuser does not emit any mist
Did you find a solution? I just received mine and have the same issue.
Mar 12, 2013 | Young Living Aria Ultrasonic Diffuser
Young living aria diffuser not misting
I am having the same problem. I have no misting at all, only music and colors. I am going to try moving the glass spout so it's opposite the plastic spout--i read that somewhere. I'm also going to start over again with filtered water. I had gotten into the habit of just reflilling and adding more oils. hope this works and helps you too!!
Nov 27, 2012 | Young Living Aria Ultrasonic Diffuser
The light diffuser cover is broken. The model number of the range hood is HO60488. The range hood dates back to possibly the late 1950's when the house was built.
When faced with the total unavailability of replacement parts, its time to get creative, and make your own diffuser cover. Flat ones
can be easily made - find anything plastic that's semi-translucent (like a plastic milk bottle), and cut it with a utility knife.
I have also used a utility knife to cut a polystyrene diffuser cover
originally intended for a 2-ft x 4-ft suspended ceiling fluorescent light fixture.
In case the diffuser cover you make wants to burn when placed close to a light bulb, replace the bulb with a CFL (compact fluorescent) bulb, which run MUCH cooler than incandescent light bulbs.
Old lampshades can be cut and used, but may need to be ironed flat. The major advantage of lampshade material is that
it can be folded over at the edge once or twice, which will fill space - and possibly hold the cover where a plastic sheet might be too loose.
You'll know that your efforts have met with success when you can easily remove your ne diffuser cover to replace the light bulb.
Feb 20, 2011 | Venmar Kitchen Ranges
How to replace light globe in Chateau Grange rangehood
I have a 600mm Chateau range hood with the same problem. To access the globe chamber, you need to first remove the plastic diffuser from the underside of the rangehood. Located at one end of the diffuser will be a small slot approx 10 mm long. Insert a small flat blade screwdriver into this slot and carefully depress the plastic tongue of the diffuser by gently pushing the head of the screwdriver away from the diffuser. As the tongue disengages from the frame you should be able to grasp the edge of the diffuser and pull it away from the frame. Once the diffuser has been removed from the frame, you will be able to change the globe.
To reinstall the diffuser, insert the plain end of the diffuser into the frame of the the rangehood (above the globe) and gently push the clip end back to its flush position.
Nov 17, 2009 | Kitchen Ranges
Light diffusion
what model of projector? i can't make an accurate diagnosis without that info.
Jul 06, 2009 | InFocus Office Equipment & Supplies
Young Living Home Diffuser - U.S.A./110v Logo
1,435 people viewed this question
Top Young Living Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Young Living Health and Beauty Expert? Answer questions, earn points and help others
