Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Dandy 8.8 fridge not working but freezer does
Freezer is nice and cold but the fridge doesn't work at all. I think the unit is only a few years old...Any suggestions?
Defrost it
back panel removes from freezer side
its not allowing air flow over to the fridge
hope this helps
Posted on Nov 29, 2007
Fridge too cold!
don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
Dec 01, 2011 | Refrigerators
My Whirlpool ET8WTKXKT0 doesn't cooling down. The fan is working, but the compressor like dead. What I have to check? Thanks. Victor
Its the problem with compressor,The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Whirlpool ET8WTKXK Top Freezer...
Westinghouse Upside down Fridge Freezer Model #BJ504T-R5. Fridge will not go cold, cannot have a a Cold Beer out of it. Any suggestions on how to fix this problem? Freezer works OK
put the beer in the freezer for 30 mins,that should cool it nicely.....
oh, the fridge aint working, sorry,poss the thermostat or (still thinking about drinking warm beer, ugh...)have you tried cleaning the vents...
Aug 18, 2010 | Refrigerators
Not cold enough
this could be just a thermostat problem or the unit may need to be "re-gased" and a new compresor
however its 25 years old???? dont you think you have had your moneys worth out of it yet??? its going to be a lot cheaper to buy yourself a nice new unit
ps,,your food wont keep in your freezer unless its at least -18 begrees F,,,, but take hart,,look at the funny side of life,,,at least you can still make yourself some hot drinks in the fridge ??? ha ha sorry!
Jan 17, 2010 | Refrigerators
Kelvinator N480s Freezer working, fridge not cooling
this can be caused by a few things. The fan in the freezer not running thus not blowing the cold air to the refrigerator(the cooling always comes from the freezer with a blower fan moving the air to the refrigerator.) it can also be a bad defrost timer not turning on the automatic defrost thus you get a big block of ice in the freezer and no cold air can get by this to the refrigerator. you can check to see if this or the defrost heater is bad by turning off the complete unit overnight.(make sure to put all your food in coolers or some other way to keep it fresh.) the next morning turn the unit on and if after a few hours your fridge is cooling nicely, either the timer or heater or bad. these can be tricky to locate and replace without experience or someone hands on showing you how to find them. Also on newer refrigerators(probably the last 6-10 years) all the components are printed circuit boards. and I have no experience with these.
Nov 28, 2009 | Refrigerators
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Freezer fan not working
Peace Friend,
ngfam1 At your service!
If the freezer is cold and not the fridge, you need to make sure the freezer is filled to the top and covering the cod air vents and passages usually found in the rear or bottom rear of the freezer!
If they are blocked or covered whit packages the unit will not be able to transfer cold air to and from the fridge!
Yes, they share the air in most refrigerators!
What type fridge,model and age?
If not only a trained tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
Sep 02, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
freezer works but fridge wont cool
Aug 29, 2008 | Freezers
Refrigerator stopped working, freezer works fine
I turned off the refrigerator and left the freezer door open so the coils and the vents could thaw out. The cold air was not getting to the refrigerator section because of ice blocking the vents.
May 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
133 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
