SOURCE: Royal 85X 10 Sheet Shredder
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc board, contact manufacturer for more info.
SOURCE: Replacement gear for Royal PX100MX shredder
For replacement parts call Royal at 1-800-524-0799; they should be able to help.
SOURCE: I own a Royal RL170MX shredder. I turn on the
If the blades rotate then the paper should go in...just be sure the blades are turning in the forward direction and not in reverse.Also make sure you lubricate the blades with shredder oil.
SOURCE: My Royal VF700 shredder will not turn off
Try giving the EYES in the middle where you insert the paper a clean...if that dosnt work you may have lost the pcb inside ...give Royal a call at 1-800-524-0799 for parts assistance.
