Re: Can a blue dot on a tv screen get worse or stay the...
One little blue dot is not enough to warranty the television. If you read all the documents on the set, it will tell you that some imperfections in the display are allowed. The good news is that it wont get any worse
The blue dots are due to a failing optic block. The lamp is only making them show up more obviously. The TV is probably failing as the blue dots will get larger and eventually take over the screen.
if just a single tiny dot it is a bad or defective pixel in the front panel-usually there from first time the unit is powered up but from a distance may not be noticed--almost never gets worse or increases in size. Unless set is under warranty do not worry about is as a Panel(entire front screen unit) usually costs more to replace then the entire TV.
The model indicated uses what is called a Optical Light Engine, it is a very expensive part and likely is your problem---not much else will cause this trouble.
well u have stopped ur movies(dvds) to many times and the dots are burn marks on ur screens if u read ur manual it will tell u NOT to leave a still picture on for to long as it will damage ur screen i assume u have a PLASMA TELEVISION if not... sorry cant help u
The Blue dots or discolouration you are seeing is due too the Blue LCD screen having cracked from excessive heat. This normally happens when you have a power failure while the Television was on. This obviously because the Blue LCD sits next to the lamp - the main cause of heat. The correct part number on the 60" is A-1086-952-A. It is very, very ,expensive.
Sorry to have been the bearer of bad news. Good luck : )
