Question about KitchenAid KSB5 Professional Stainless Steel Work Top Blender
Motor won't turn on
My blender won't turn on. When plugged in to various outlets, unable to get even the "On" light to come on. Worked fine one day, the next, no luck. I use this daily, and have never had a problem (other than I replaced the coupler several months ago).
    Master:
  • 619 Answers
Hi , Try to check with multi tester the power cord ,test the two tips of male outlet switch on tested read the continuity /if not reading ,pulout if push type /if permanent open cover below test the test the cord inside to the male plug if does not response cord is problem,check also fuse test both end of fuse not reading fuse buste then replace thats all goodluck.
Posted on Jan 14, 2008
Why won't the blades turn?
One or both of the drivers are broken, check the clutch on the top of the motor and the other one on the bottom of the beaker. You will find something there worn out or broken.
May 24, 2015 | Blenders
Blender malfunction
can you hear the motor working.
Jul 14, 2008 | Krups Blenders
Blender won't work
The switch may have failed.
Dec 06, 2013 | Oster Blenders
The unit will not turn on (after being moved)
Sounds like a bad cord. There are lots of cheap cords that fail easily these days.
Nov 07, 2013 | Sunpentown WC-1682 16 Bottle...
I reveived the 48952 food fusion 2 years ago, used it twice and put away as I had another one. I took it out of storage today but it won't work. I have tried all the attachments and no attachment but the...
Plug something else into the electrical receptical to verify you have power from your outlet. Then remove bottle and blade assembly; and press the two small black micro-switches inside the base of the blender. If your blender still won't turn on then you may have a faulty motor or motor connection.
Dec 20, 2017 | Morphy Richards Food Fusion Hand Blender...
Breville blender won't turn on. The on light is flashing red instead of solid blue. Worked fine a few days ago.
FIXED IT - It's the screws on the bottom of the jar assembly, where the blades are attached. There are 4 Torx screws - star-shaped - and when these come loose over time the Blender will start to operate only sometimes. Eventually it will be never.
Tighten these four screws and everything will be fine!
Oct 02, 2010 | Breville BBL600XL. 5-Speed Blender
Blender died ...... motor won't turn on
Have you tried the fuse first....
If it is the motor (quite rare), these people may be able to order you one:
http://kitchenaidblenders.co.uk/Home/tabid/36/c/KitchenAid-Blender-Spares/CategoryID/6/Default.aspx
Aug 10, 2009 | KitchenAid KSB3 Classic Work Top Blender
Blades won't turn
If the problem is that the blades are jammed and you can't turn them manually, you can let it sit ( and dry out ) for a few days, or you can try adding some oil. I had the same problem and this worked. My problem now is that the blades don't reach to where the motor is turning, so even if they're not jammed the don't turn. If anyone knows and answer to this I'd appreciate it.
Jan 24, 2008 | Oster 6678 14 Speed Blender
Blinking lights on KitchenAid blender
Alternating blinking lights on a Kitchenaid blender indicate a bad circuit board which is unable to run the motor properly. Unplug the blender, take the jar off, and turn the spindle by hand. Then plug it back in. If it does not work properly, try a different outlet (perhaps not in the kitchen). If nothing works, the blender needs to be repaired.
Aug 27, 2007 | KitchenAid KSB3 Classic Work Top Blender
KitchenAid KSB5 Professional Stainless Steel Work Top Blender Logo
960 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
eyecam
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
