Question about Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-57WS510 Convergence issue?
I have a Sony KP-57WS510. It has worked perfectly for 4 years. Just yesterday the image on the TV had a concave top & bottom, but is straight on the left and right sides. You can see the red, blue and green images separate on the top and bottom of the image. The center of the image is fine, and in focus. Any idea what the problem might be?
  • slickgib Apr 17, 2008
    had this tv for just over 4 years and go to turn it on yesterday and all the lamps are out of wack and i have weird strang green lines at the vary top going back and forth. wierd. called a repair company and they said it will be 100 to check it out and another 250 to fix.
There should not be a need to replace the chip if the fuse below the convergence chip is blown. Check to see if there is a short in the convergence output (after the fuse). If nothing is seen then replace the fuse and see if it works.
Posted on Jun 20, 2008
    Guru:
  • 1,894 Answers
Sorry.. it was by mistake
Posted on Dec 25, 2007
    Genius:
  • 1,694 Answers
Replace convergence IC's....STK392-560 X 2 + check pico
fuses under IC heatsinks.....................T.
Posted on Nov 30, 2007
Hi, I have a Sony KP-57WS510 57 in. Rear
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 25, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Sony kp-57ws510 SD Tech, soldering is no
I've used them before for replacement STK IC convergence chips. Works great! Good luck!
Nov 02, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
My screen accidentally got broken but TV was working fine...is there a way to get a replacement screen? can I buy the materials to do it myself?
Sony KP-57WS510 has 3 layers front screen and I do not know what layer is broken. Part number of all 3 screens are as follows.. count it as front, middle and rear screen layers..
4-090-881-11 SCREEN (57), CONTRAST (KP-57WS510 ONLY)
4-095-924-11 PLATE (57WL), DIFFUSION (KP-57WS510 ONLY)
4-081-950-11 PLATE (57WFV), DIFFUSION (KP-57WS510 ONLY)
Also check HERE for your TV screen.
Aug 04, 2009 | Sony KP-65WS510 65" Rear Projection...
Tripe image, blue, red and green color on image, not focus
you will need to replace the two STK392-560 ICs and also check the 4.7 ohm 1/2 watt resistors and the six 3.5 amp pico fuses.
May 05, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
How to change convergence ICs in Sony KP-57WS510 TV?
Replace Both STKs convergence ICs big black ics with number on them STK392-560.Parts 1-800-223-3205
Dec 20, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony 52XBR Rear Projection
Sounds like some kinda convergence problem. Can you post an image please?
Jul 14, 2008 | Sony KP-51HW40 51" Rear Projection...
No sound Sony KP-57WS510
Brain Freeze ! Sometimes the microprocessor locks up...
you may need reset = unplug ac cord, wait, then try again..
..........T.
Jul 01, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
RED SHADOW AROUND IMAGES of SONY KP-57WS510 RPCRT
Your set uses two STK392-560 convergence ICs they are attached to a large heat sink on the D board. You can save your self about 400 for a twenty minute repair by getting new ICs at the following link as trhey provide free instalation instructions with pics so you can do the job yourself. It only requires basic soldering skills I would order about six 4.7ohm 1/2 watt resistors as well just in case you need them asusually sonys' will burn one or two of the 4.7ohm convergence resistors when the ICs fail. Heres the link
http://servicemanuals.vstore.ca/
May 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Red shadows and mild distortion
Hi, relasmith did you ever fix your tv kp-57ws510
thank you
Apr 03, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57WS510 57" Rear Projection HDTV Logo
268 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
