Question about Magellan RoadMate 700 GPS Receiver
No power to unit, but powers on okay in house with AC power adapter
So obviously it's the cigarette lighter adapter cable. But the cable has not been abused at all. The green light on the cigarette lighter adapter cable indicates that it is plugged in. Could it be a fuse if this light is on? The unit stopped working while plugged into my husband's old work vehicle. Ironically, when he plugged his iPod into the cigarette lighter, a fuse blew in that cable. And, we borrowed a Garmin GPS this weekend and plugged it into this same vehicle, and it worked fine for a while. But then it stopped working. It ran off of battery power for a while, so I know it must be either the cradle or the cigarette lighter adapter cradle. But I need to find out quick! So is it possible that the fuse is blown and that green light is still on? And on my Magellan, I thought it was the cradle, because when it first started acting up, it would turn off, but then I would play with it a little bit, and it would turn back on. Now it won't turn on at all. That doesn't sound like a fuse, does it?
  • 5 more comments
  • alwaysfixin Nov 13, 2007
    Update: I opened up the Magellan and the fuse appears to be fine. The little wire inside is not broken.
  • alwaysfixin Jan 08, 2008
    I bought a new cigarette lighter adapter on e-bay for $17 (including shipping,) and it's been working great ever since! Thanks.
    And why would I throw away a $300 unit without trying to fix it first? I though that's what this site is for (people who want to fix things, not be told which one to buy instead.)
    Thanks. I still don't know why the power cable failed, but I have a theory. I remove my GPS from my car on a regular basis to prevent theft. Most people probably disconnect the cradle from the unit, leaving the cradle and power cable behind (I'm assuming.) I always leave the cradle attached to the unit, and disconnect the power cable from the cradle, and leave just the power cable in the car. I happen to own an otoscope (the tool that doctors use to look inside the ear.) I used the otoscope to look inside the end of the power cable that attaches to the cradle and I saw what looked like a spring-loaded clip (I lack the technical terminology, sorry.) Anyway, I suspect that this spring loaded clip has exhaused it's spring, due to my continuous use. I could cut the thing open with a blade and look further, but I'm too lazy now that the thing is working. :)
  • eleigh1979 Feb 21, 2008
    My magellan wont stay on! I dont know what the problem could be!
  • LONZO1964 Mar 10, 2008
    MINE IS THE 700 MAGELLAN SERIES AND IT WORKS BUT IF YOU MOVE THE CORD IN THE CAR YOU HAVE TO PLAY WITH IT TO GET IT TO COME BACK ON. WHAT DO YOU THINK IT COULD BE?
  • Ponchito Apr 12, 2008
    I found that the cradle is the problem when you loose power, the connector that you plug into is usually broken at the center pin. I just take the cradle apart and remove the pc board and unsolder the connector, then hard solder the cable with plug cut off to the circuit board. Remember to feed cable through plug hole on cradle half, and then I tie down the cable to the circuit board to relieve the strain on the soldered connection, put it back together- a little tricky, I find a loop magnifier very helpful. Hope this helps
Not sure if you'll see this post, as you asked the question back in Nov, but I
thought I'd tell you what I know anyway.
I and my parents bought the same exact unit within a week of each other.
There's works, and mine does not.
I took their cradle, and hooked it to my GPS, and it came on, no problem.
I took my cradle, and hooked it to theirs, and boom, nothing.
So, with that, I was able to isolate that the problem is definitely in the cradle.
I went to the manufacturer website, registered my Magellan Roadmate 700,
and then I was able to contact customer support. I am writing to you as
I wait for their reply. Here's their website.
https://www.magellangps.com/users/registrationHelp.asp
Hope this helps!
Posted on Feb 26, 2008
I want to know if my Duracell 130 Watt AC/DC Power Adapter can be used to plug in a coffee maker into my cigarette lighter? I also misplaced the User Manual to this product. Can it be replaced. I believe...
It's not a good idea to run anything that needs a lot of wattage through a power converter using a 12v cigarette lighter plug. Coffee makers work by using a resistant heater element and it might work, but you could damage the coffee maker or the adapter by doing so.
Mar 04, 2015 | Duracell Electronics - Others
Broken RoadMate 700
Here are a few tests you can do. Bear in mind if the unit has not been charged for some time and the internal battery is completely flat, you will need to leave the unit on charge for some time even to get a charge light from the LED. Leave it on charge for at least 2 hours. First, check the LED is lit when the cable is plugged in to the cigarette lighter socket and/or mains charger? If it is not, the fuse in the cigarette lighter adapter may be faulty or the charger may not be working. If the fthe LED is lit, then is power available at the end of the cable that connects to your unit? Use your DC voltmeter to check this. If no power is available here, then your cable/charger is faulty - obtain a new one. If there is power at the connector, then the unit may be faulty.
Jun 10, 2007 | Magellan RoadMate 700 GPS Receiver
How do I recharge the battery on my Garmin Nuvi 255WT? I would also like to know how to update my Garmin?
Recharging the battery is done by connecting the nuvi to a vehicle power cable in the car through the vehicle power accessory outlet or cigarette lighter.
The unit can also be charged via a powered USB port off your computer via the USB power/data cable or an AC power adapter through the USB power/data cable.
Aug 15, 2011 | Garmin nuvi 255W GPS Receiver
2001 Avalon cigarette lighter has no power, 5A fuse is okay, instrument panel works, although I think the light for the glove compartment is also out
There are 2 common problems for this, 1 is the power connecting wire to the lighter housing falls off, or if the wire is connected and has power, the lighter unit itself has an internal open circuit and needs to be replaced.
Jul 09, 2011 | 2001 Toyota Avalon
Did self check on start up and then stopped working fuse and power supply are okay
You checked the fuse that is contained inside the cigarette lighter adapter, correct?
If that fuse is blown, get a new one at your local electronics store.
You should also verify that the power from the cigarette lighter adapter is on. You can do that by testing it with the actual lighter, or you can use a voltmeter or test light to determine if power is reaching the lighter outlet.
Oct 27, 2009 | V1 Radar Detector
Just want to know if there is a power adapter for this where I can get power from car cigarette lighter
There are adapters to a car lighter for all kinds of AC plugs but not usually very strong. Laser printers can take alot of power. How many WATTS does the powers cord say? Here is one that does a 160 continuous and 300 peak. Check the amps too before you buy, but there are a multitude of these they are called DC to AC converters.
Apr 27, 2009 | Konica Minolta PagePro 1350W Laser Printer
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Karen died
If the unit works on battery but not the AC adapter or cigarette lighter adapter, obviously the problem is in the adapter.
1. Have you verified that you have +12VDC at your accessory jack?
2. Have you checked the fuse in the cigarette adapter?
What are you powering it with when not on the battery?
- Jim
Feb 15, 2008 | Garmin StreetPilot c340 GPS Receiver
Rwr supply
Buy an adapter such as the one in this link to convert AC power to a 12V "cigarette Lighter" outlet.
http://www.amazon.com/Universal-Cigarette-Lighter-Socket-Adapter/dp/B000EG8RIM/ref=sr_1_5?ie=UTF8&s=wireless&qid=1207184215&sr=8-5
Feb 06, 2008 | Audiovox PVS72901 Portable DVD Player
Magellan RoadMate 700 GPS Receiver Logo
160 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
