Question about Archos AV 500 Digital Media Player
Help no past start up
My archos seems not to will turn on when its plugged in but not go past the startup screen...and when i try to turn it on on its own,it wontt get past the start up there anything i can do?:(
This is what happened to me in my thread here :
Im ringing them tomorrow to sort mine out.
Not sure how the other guy went, he never updated how it turned out
Posted on Feb 26, 2008
My archos 5 IMT 160 gb has a blank screen. It looks like is charged. I makes noise while is starting up, but the screen is blank. I* charged for over 10 hours.
Screen is blank?
Do you mean you won't see anything at all like the signup colorful screen that says "ARCHOS Entertaining your way" ?
If your battery is full charged (did  the CHG LED green light blink when it finished charging?), and you have a blank screen, do you have a serious problem indeed. If your unit is under warranty your best and only way is contact Archos.
If when you turn it on, it takes you to the Recovery screen (white screen, usually says Code 101) then try to Format the HDD, download the latest firmware from for your unit, copy it from your PC to the Archos, let it finish the process wth the power supply connected, and once it's done the unit should be back working fine with the latest fimware.
But if you definetely do not see anything but a blank screen when you turn it off, your problem is more serious than a simple firmware upgrade, and you need to contact Archos tech support.
Mar 08, 2010 | Archos Internet Media Tablet MP3 Player
Archos Av500 startup problems
its a HDD or OS failure
ull have to ask the company for a replacement if its under the warranty period
make sure to register ur device on the Archos website to get a 'Technical Support Passcode.'call Archos to tell them ur problem and if ur lucky they wud repair it free of charge
if u want to try it urself...i found this one of the forums on the net..
1.remove all the screws, and remove the battery.
2. Remove the hard disk from the player by disconnecting the ribbon connector carefully from the mainboard.
3. Try to startup the player after putting the battery back in place. This time, instead of turning off, the player showed a "cannot read hard disk" error with the option of formatting it. Made me realise that the hard disk was the culprit. However, I had heard the hard disk noises previously, and they sounded fine, so I realised it was a software issue (file system was corrupted)
4. Try to connect it back, same problem as before... Also it is very difficult to first start the player & then connect the hard disk, as the player is designed to shut off in that situation.
5. The best option after this would be to get a drive enclosure designed specifically for 1.8 hitachi hard disks to connect the disk directly to the computer using USB and format it.
6. However since I didn't have a specialised enclosure, I did a lot of trail and error with the player itself (running off mains while connecting the hard disk after starting the player without releasing the power button etc etc etc) which Im sure wasnt too kind on the hard disk, but voila, I managed to start it up fine WITH the hard disk in place without the player turning off using some weird combination of holding down the power button and connecting the ribbon on the bootup screen)
7. After this, he was able to select "format", and the player began working fine he lost all the data on the player itself, but luckily he had backups of everything!
Thanks for using Fixya
Jul 16, 2008 | Archos AV 500 400-Hours Video Recorder
Archos 5 frozen screen
I have found a solution for this issue, if you hold down the volume button and the power button for several seconds the Archos goes into a restore type mode. You then plug it into your computer and download the latest firmware update and cut and paste it onto the archos removable hard drive icon that appears in my computer. It will take a few minutes to update but then it will work perfectly.
Feb 03, 2009 | Archos Internet Media Tablet MP3 Player
I have a 605 wifi and it sits in the charging platform. I cannot get it to turn on past the Archos titile page and then it seems to fade and fail like there is no power. It is only 8 months old. Is the...
Hi have you got your power supply plugged into the charging platform??, It would appear you have insufficient charge in the batteries on the 605.
If you have the USB lead plugged into the charging cradle this would normally ask you to select either charge or usb.
What does the CHG. light on top of the 605 do when you plug the unit into the cradle ?? (steady green-- charging. flashing green-- fully charged)
Dec 03, 2008 | Archos 605 WiFi Digital Media Player
When I plug in the charger (i know its the right one) well it wont charge. Im not sure if its just the charging light but I cannot turn it on.
Dont worry .Insert your plug into archos charging line. On home screen of archos asked you to charged or enable option select charge only option and simly get charged yr archos within 3- 4 hrs of time.
I hope u understand this description.
Nov 16, 2008 | Archos 605 WiFi Digital Media Player
Archos seems to have Bricked itself
my archos just goes back to code 102 and i have tried it several times
what do i do now
please help
Apr 23, 2008 | Archos 605 WiFi Digital Media Player
Just watching a movie and my archos just froze in mid play , did a switch off to rest it and guess what it wont restart , ses ARCHOS in green at the start but wont reeboot have tried the reset button inside but no joy what so ever , any tips or advice 'or shall i just ship it back to Archos ....
Jan 05, 2008 | Archos 605 WiFi Digital Media Player
AV700 wont even turn on
have you tried resseting the unit?
Dec 23, 2007 | Archos AV700 Digital Media Player
Archos gemini av 500
Is the drive recognised by your PC when you plug the Archos into the computer?
Mar 02, 2007 | Archos AV 500 400-Hours Video Recorder
Archos AV 500 Digital Media Player Logo
132 people viewed this question
Top Archos Audio Players & Recorders Experts
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
