Question about Emerson Black Microwave Oven
Help inside tray will not rotate
I have the red stainless steel microwave. It works with the exception that is will no longer rotate inside. There is no help in the owners manual.
Any assistance will be appreciated!
  • maimee Nov 13, 2007
    already did that -
  • 225 Answers
Check rotated plate and connecting surface ok.
Posted on Nov 13, 2007
Kenmore 62463 / 721.62463201 Stainless Steel 1200 Watts Microwave. My daughter used it as a timer for reading and set it to cook for 30 minutes with nothing in it. It turns on but is loud and no longer...
You probably fried the magnetron(it actually makes the microwaves that do the cooking). I bet you will find the magnet is broken(from excessive heat). There should be a diagnostic guide sheet somewhere inside the housing(due to running production changes,this is a guide for the pros to test the power supply,magnetron,etc with an ohmmeter to determine which is defective.
Sep 18, 2013 | Kenmore 62463 721.62463201 Stainless Steel...
Lmvm2085st glass tray not rotating
The problem is most likely one or two door switches are bad, usually caused by food partical build up, replacement needed.
Mar 17, 2012 | LG LMVM2085ST Stainless Steel 1100 Watts...
I seasoned my new stainless steel skillet in the oven now I have built up oil stuck to the sides inside the skillet. How can I remove this without damaging the stainless steel finish? HELP!
You only need to season a cast iron skillet, not stainless steel. Soak it in hot soapy water and use something like a mister clean pad to clean it.
Dec 07, 2010 | Microwave Ovens
The plate no longer rotates around since we defrosted an item that leaked below.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ,.
Oct 24, 2010 | Whirlpool GT4175SPS Stainless Steel 1200...
No heat on magic chef microwave
Check the door safety interlock switches.
Dec 29, 2009 | Magic Chef MCD1311ST Microwave Oven
How to clean GE Advantium???
Get a stainless steel "brillo pad" at the grocery store.
When you get home ... put a microwave safe container with water inside it ... in the oven. do not heat for more than 2 minutes!!!!! The resultant steam will soften the gunk. Use the stainless steel cleaner pad gently to remove the goop.
I hope this helps you
Sep 23, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave oven not heating thoroughly
u need to clean the cavity inside the microwave .. step to clean that .. put a cup of water nearly half filled( 30 ml ) and start microwave for five minutes .. after that just open microwave and clean from inside with clean cotton cloth .. this will surely help ..
Mar 23, 2009 | Kenmore 63683 Stainless Steel 1200 Watts...
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you .
Mar 01, 2009 | Microwave Ovens
Microwave stopped heating, evenything else works
Jan 03, 2009 | KitchenAid KCMS1555RSS Stainless Steel...
Amama 2.0 Cu ft. Radarange Microwave model# UXA3036BAB
This model does not list Stainless Steel as a feature. Stainless Steel is used in the interior (CAVITY) of a Microwave if it is a Combination Convection/Microwave Oven. The Convection Oven can reach temperatures of 400+ degreesF. This Temperature would MELT the paint off a painted interior.
Stainless Steel can be tested with a Magnet. It will not be attracted or "Stick" to Stainless.
Hope this answers your concerns!
Feb 05, 2008 | Amana ACM2160A Microwave Oven
Emerson Black Microwave Oven Logo
136 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
