Bosch 11247 1916" Spline Combination Hammer Logo
A
Anonymous Posted on Feb 22, 2015
Make a Bosch 11247 hammer? - Bosch 11247 1916" Spline Combination Hammer
2 Related Answers
Anonymous
  • 154 Answers
  • Posted on Apr 13, 2009
SOURCE: Bosch 11247 Hammer drill works
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
puertobori
  • 7733 Answers
  • Posted on Nov 02, 2010
SOURCE: I NEED A ARMATURE FOR
Go to eReplacementParts.com : Power Tool Parts and Tool Repair
11247 parts manual
John,
Try the following link. You may have to register, which is free, to be able to get a parts diagram.
Bosch Power Tools Contractor Tools Accessories
What type of oil do I use in my Bosch 11247 rotary hammer
It says on the drawing Renolin PGW150. 50ML
Apr 14, 2013 • Drills
BOSCH 11247 Hammer Drill will drill but will not hammer. Opened the transmission case and no parts broken but low on oil. Could that be why the drill stopped hammering?
Top up the transmission with PAG150 oil. The Bosch stuff is hideously expensive, but it's the same as the 150-grade oil used in car a/c systems. I fill them so the oil *just* covers the big gear.
Bosch 11247 rotary hammer will not hammer
SAME ISSUE *****SOLVED*****
You were on the right track but needed to go farther with top description without disassembly!!
I have a barely used Hammer drill also that will rotate and run motor but does not hammer in any position.
Grease is the issue.....
Heat and sitting causes the grease to weep out & even a small amount of dust binds up the hammer drill.
******SOLUTION*****
GREASE, GREASE & MORE GREASE....
REMOVE BIT....SQUIRT IN ALOT OF THE BOSCH GREASE HOLD LOCKING CHUCK OPEN. INSERT A SPLINED BIT INTO THE HOLE AND PLUNGE GREASE IN SLOWLY SEVERAL TIMES. REMOVE BIT & REFILL GREASE & REPEAT.....VOILA.....HAMMER WORKING AGAIN....
BE SURE TO USE LOTS OF GREASE & DUST COVERS ON Bosch HD WHEN WORKING. WE ALL ERROR AND FAIL TO MAINTAIN FROM TIME TO TIME!
Feb 19, 2012 • Drills
Bosch 11247 wont hammer
hola le hace falta aceite a los engranes por eso no golpea puedes usar aceite para transmision
1helpful
I want to run this drill at the end of a 250' AWG 10 extension cord. How much voltage drop can this tool tolerate?
Most ac motors will run with a +/- 10%. Quick calculations say you drop will only be 2.3%. You should be just fine.
Bosch rotary hammer (model # 11230EVS) drill will not rotate
There is a clutch in the main spur wheel of the unit. These sometime begin to slip, on rare occasions they will slip to the point where the drill will not rotate. If you are interested the part number for this clutch is 1617000817.
Bosch 11247 Hammer drill works in drill mode but in hammer mode it spins as drill but does not hammer. Also how can I remove drive shaft from housing?
Top Bosch Drills Experts
Paul Carew
john h
Are you a Bosch Drill Expert? Answer questions, earn points and help others
