Question about Flat Panel Televisions
Samsung TV screen problems
My new 46" Samsung LCD TV is infrequently flashing like a stobe light on the bottom half of the screen. I can usually turn the TV off and back on again and it will quit. Any insight?
  • 1,392 Answers
Re: Samsung TV screen problems
The fluorescent backlight tube in the LCD display is defective. Replacement requires a lot of disassembly to get into the back of the LCD panel, and changing the tube takes some very delicate soldering work - rather more difficult than printed circuit repair.
Posted on Dec 13, 2008
  • 67 Answers
Your new Tv needs to go back to the dealer. This is not Fixable by yourself...
Posted on Nov 13, 2007
0 characters
3 Points
My vizio is flashing like a stribe light
Sounds like the ballast board that controls the back light for the screen is failing. There is a possibility that the light tubes need replacing too.
Jan 04, 2014 | Vizio L32 32 in. LCD HDTV
Tv wont power on red light continuously flashes
Hi,you need to have the capacitors in the powersupply replaced
Oct 15, 2013 | Samsung UN46D6400 46 Inch 3D 1080p Smart...
I have a 46" Samsung LCD tv that won't turn on. When I press the power button you can hear the chime sound it usually makes and you can hear the relay click and the screen flashes quickly then goes bl
sounds like you have a back light problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flash light on the screen. If you see the faint picture on the screen, you have a back light problem. You could either have a shorted inverter that is pulling down the 24vdc line, a blown CCFL back lamp, a high voltage short (arcing) from one of the inverter outputs, or a faulty 24vdc power supply
Dec 09, 2012 | Flat Panel Televisions
Samsung LCD 46 inch half of the screen is darker than the other half.
Hi, while fixing another persons lcd tv i used lower rated power supply to try to fire up the tv ( picture-no sound) the bulbs ( actually cold cathode fluorescent ) lit up but only halfway. So sounds like the power supply for your backlight has gotten weak. You may try a workaround I've used on personal equipment, try turning down brightness on tv-this may,if your lucky, even out the brightness. hope this helped. Prodzilla
Mar 30, 2011 | Samsung LN46A650 46 in. LCD HDTV
My Samsung TV 46" LNT4671F
This is due to low voltage getting to the Inverter board or the Inverter board on the bad side is not lighting the lamps. Usually bad capacitors or the power supply and the inverter will cause this symptom. You may want to replace both inverters boards on this model, new models have one inverter board for both sides of the backlight.
Nov 10, 2010 | Samsung Flat Panel Televisions
When I trun on TV (Samsung LN-T4661F 46 In), it start with half scrren dark from Right Side, time goes by being normal screen. I want to know what the problem is.
Samsung made a bad TV, the new part is $1200 I have the same issue. it is a blurred picture from left to right after about 10 min it goes away. (18 month old tv) it is only going to get worse.
Jun 05, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Picture and sound going out- flashing lights
the problem its the main board it controls everything if no warranty go to better prices better than manufacturer and tv repair man
Apr 13, 2010 | Samsung LN46B650 46/49.5 in. LCD HDTV
I had a repair guy come and he's like yah I'll update the chip in your 46" samsung T.V. He leaves and also breaks my Hdmi cable to my xbox, but my parents said they'd pay cause he "fixed" it and then I...
These sets have a common problem with the power supply board. bring the set to an authorized samsung repairer.2-4 capacitors are usually at fault with parts and labour usually between $100-200.
Nov 08, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Cracked lcd tv screen
Lcd and PlasmaPanels typically run from $900.00 to $1500.00 retail. If you have a trained samsung tech replace the Panel, you are looking at or near the cost of a new tv all said and done.
Jul 02, 2009 | Samsung LN46A650 46 in. LCD HDTV
Strobe-like flickering in upper half of Dell monitor
The problem is the inverter on your dell monitor this is very comon.
Jun 15, 2009 | Gateway XHD3000 LCD TV
Flat Panel Televisions Logo
349 people viewed this question
Top Flat Panel Televisions Experts
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
