Question about iRiver H10 MP3 Player
Iriver (h10) when i turn on my iriver it says system files missin , to restore files , connect h10 to recovery tool . (www.iriveramerica.com)
  • 1 more comment
  • Anonymous Nov 13, 2007
  • elektromann Dec 07, 2007
    I cant turn on my H10 .I have take off the battery one or two even three times to get it on and then all my playlists are gon as well as the clock. Any tips anyone?
  • LOMz May 04, 2008
    emergency connection
    system files missing - To restore the system files, connect H10 to recovery tool (www.iriver.com).
    this msg is on my iriver when turning it on .
    please help
Either find rockbox or iriver plus and do a firmware upgrade
Posted on Nov 19, 2007
System files missing
I got this from another post:
1) plugged in H10 to pc that didn't have any iriver software on it
a) I've read if you press the "o" button on the iRiver H10 when connecting it will just connect as a usb mass storage device
2) the H10 now appears as a mass storage device
3) right click on the drive, and select format ( I choose quick format)
4) install the iRiverFirmware updater from http://iriveramerica.com/support/mtpupdate/
5) when you run the updater, it found the H10, then asked if the device was from USA or Europe, mine was from Europe
6) It stated that the iRiver firmware was v0.0, and would install v2.51 (I've seen v2.53 available on the european iriver website but could not download it).
7) proceed with installing the updated firmware
8) on the last screen it says, unplug to complete firmware update - NOTE press Finish first before unplugging
9) switching on the iRiver it 'rebooted' a few times and then when the menu appeared, I connected to the pc and just dropped some mp3 files into the music directory and all was okay.
hope this helps.
Also go here for the firmware directly: http://iriverinc.com/support/hd/h10_5-6gb.aspx
Apr 13, 2009 | iRiver H10 MP3 Player
Restore the system files, connect H10 to recovery tool
The procedure depends on what version you have.
Below there is the procedure for 20 GB , on other models procedure is the same, but you must find the right download for your model.
For 20 GB :
TO RESTORE "SYSTEM FILES MISSING" LOCKED PLAYER
--- This applies ONLY to the 20 gig version of the H10! ---
--- This procedure formats your H10 so all data will be erased on the player! ---
1. Power off H10 - 20gig unit.
2. Insert staple or other small object into reset hole to press reset button.
3. Connect player to USB cable.
3. Hold down Select key (labeled "O" - right button on front of player) while also holding down power key until player boots.
4. Unit must display "Emergency Connection."
5. Unit will now appear as a drive under My Computer. Right click on drive, select Format. No need to change anything, just proceed.
6. Download H10_20GB_System.exe. It is a self-extracting archive. Double click on it and unzip to c:\iriver.
http://www.iriveramerica.com/downloa...0GB_System.exe
7. Locate iriver directory, double click. You will see H10. Double click once again; you will see System.
8. Right click on system, select "Send to" and choose the directory of the player.
from System Files Missing
If you have the 5 or 6 GB see iriver - H10 5/6 GB Series Support
Feb 24, 2009 | iRiver H10 MP3 Player
IRIVER H10 system files misssing
you can just go into the shop you bought it from or dicksmiths or something and they would sell the disc
as for your computer one just plug in your device then when you think it has loaded and everything go in to my computer and it should have your device there!
Oct 12, 2008 | iRiver H10 MP3 Player
I need to restore the system files for my H10 Iriver MP3 player
go to www.iriver.com people - what the f--- do you think it means?
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 04, 2008 | iRiver H10 MP3 Player
Iriver H10 sistem files missing problem
just go to iriver.com iriveramerica is more of a store search, got to the iriver website find your device click on its page and then at the bottem it will have relevant updates as well a firmware recovery tool, if not just do a search on their website it is not a player specific tool
Mar 22, 2008 | iRiver H10 MP3 Player
6 gb version of H10 displaying error message on start up
you need to upgrade firmware to version 2.51 using the mtp upgrader download found at www.iriver.com-support-ask.asp after doing this your player should work this upgrade is a recovery tool and works very well with all mtp version players
Dec 30, 2007 | iRiver H10 MP3 Player
Iriver h10
Get recovery tool from iRiver website
Sep 06, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
366 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
